LogicMachine Cloud solution _ Support
(05.12.2018, 10:08)Triet Phan Wrote:
(04.12.2018, 12:37)Daniel. Wrote:
(04.12.2018, 12:35)Triet Phan Wrote:
(04.12.2018, 11:47)Daniel. Wrote: The cameras are bit tricky.  The cloud does nothing in term of video conversion. If you have camera stream available remotely in mjpeg format then you can use video widget which has place to local and remote url.
I saw there are 2 places for putting url of camreras. Local URL is for when owner inside his house and Remote URL is for when he is outside his house, is that right , Daniel ?
Correct. When connected via cloud then remote url will be used to stream.
Hi Daniel,
remote URL and local URL to put on video widget are the same ?
No, local is what you use locally with a local IP and remote is something what you can access from outside. Usually with external IP and a port
RE: LogicMachine Cloud solution _ Support - by Daniel - 05.12.2018, 10:11
