PROBLEMS IP TUNNELING WITH ETS
(05.12.2018, 04:47)CHOUAIBOU Wrote:
(04.12.2018, 16:55)Carlos Padilla Wrote:
(04.12.2018, 16:44)Daniel. Wrote: Did you try restarting ETS? The config looks good.
Yes, I tried, but It didn't work.
Hi Carlos,
There is a test button in ETS. Use this button to test the communication between ETS and LM if it is Ok or not.
If not ok, check your computer static IP address and make sure that all things are Ok.
If your computer static IP address is Ok, you can simply delete the previous connection in ETS, the software will detect automatically your LM and display a new connection. Perform a test and if ok, select it.
B.R,
Chouaibou.
Hi Chouaibou,
Thanks for your answer.
The communication test isn't ok, the IP computer's address is ok, and The software ETS detect automatically the LM but show the message as you can see in the picture. I tried with another PC but I had the same result.
RE: PROBLEMS IP TUNNELING WITH ETS - by Carlos Padilla - 05.12.2018, 13:22
