Simple HTTP - Tesla API
Usually the bearer token is a response on the token request and is valid for x minutes (mostly 60 minutes), so i doubt that 123 is the bearer code (:
Can you try this?
-- Load modules require('json') require('ssl.https') require('ltn12') -- Set credentials for Tesla API username = "admin" password = "admin" function GetToken()  request_token_url = 'https://owner-api.teslamotors.com/oauth/token'  local response_body = {}  local request_body = "grant_type=password&username=" .. username .. "&password=" .. password  local body, code, hdrs, stat = ssl.https.request{    url = request_token_url;    method = "POST";    headers =    {      ["Content-Type"] = "application/x-www-form-urlencoded";      ["Content-Length"] = #request_body;    };    source = ltn12.source.string(request_body);    sink = ltn12.sink.table(response_body);  }  if code == 200 then    ret = table.concat(response_body)    ret = json.pdecode(ret)    return ret.access_token -- could be some other field, try to log ret to be sure  end end -- Request token if not API_Token then     API_Token = GetToken() end function RequestFromTesla(request)  request_url = 'https://owner-api.teslamotors.com/api/1/' .. request  local response_body = {}  local request_body = ""  local body, code, hdrs, stat = ssl.https.request{    url = request_url;    method = "GET";    headers =    {      ["Content-Type"] = "application/json";      ["Authorization"] = "Bearer " .. API_Token;    };    source = ltn12.source.string(request_body);    sink = ltn12.sink.table(response_body);  }  if code == 200 then    ret = table.concat(response_body)    ret = json.pdecode(ret)    return ret  else    API_Token = GetToken() -- request a new token  end end function WriteToTesla(request)   request_url = 'https://owner-api.teslamotors.com/api/1/' .. request   local response_body = {}   local request_body = ""   local body, code, hdrs, stat = ssl.https.request{     url = request_url;     method = "POST";     headers =     {       ["Content-Type"] = "application/json";       ["Authorization"] = "Bearer " .. API_Token;     };     source = ltn12.source.string(request_body);     sink = ltn12.sink.table(response_body);   }   if code == 200 then     ret = table.concat(response_body)     ret = json.pdecode(ret)     return ret   else      API_Token = GetToken() -- request a new token   end end -- Get products products = RequestFromTesla('products') log(products) -- Check here your Car ID CarID = 1 -- products[1].id? -- Get onboarding data onboarding_data = RequestFromTesla('users/onboarding_data') log(onboarding_data) -- Wake up car result = WriteToTesla('vehicles/' .. CarID .. '/wake_up') log(result)
Simple HTTP - Tesla API - by Mr.D - 13.12.2018, 19:35
RE: Simple HTTP - Tesla API - by Mr.D - 13.12.2018, 19:59
RE: Simple HTTP - Tesla API - by Erwin van der Zwart - 13.12.2018, 22:50
RE: Simple HTTP - Tesla API - by Mr.D - 14.12.2018, 15:19
RE: Simple HTTP - Tesla API - by Mr.D - 27.01.2019, 12:04
RE: Simple HTTP - Tesla API - by admin - 10.01.2020, 09:21
RE: Simple HTTP - Tesla API - by alexgleyzer - 26.05.2020, 07:38
RE: Simple HTTP - Tesla API - by admin - 26.05.2020, 08:19
RE: Simple HTTP - Tesla API - by alexgleyzer - 26.05.2020, 10:35
RE: Simple HTTP - Tesla API - by admin - 26.05.2020, 11:14
RE: Simple HTTP - Tesla API - by alexgleyzer - 27.05.2020, 06:34
