Socket.io server on .lp file
.lp can already work as WebSocket server. Here's a short example:
<? local json = require('json') local ws, err = require('ngx.ws'):new({ timeout = 10 * 1000 }) -- websocket init error if not ws then   write('websocket init failed: ', tostring(err))   return end request.raw = true local lb = require('localbus') local function lbthread(ws)   local client = lb.new()   local run = true   -- telegram event   local function groupcallback(event)     event.tsec, event.tusec = os.microtime()     local data = json.encode(event)     if not ws:send_text(data) then       run = false     end   end   -- set callbacks   client:sethandler('groupwrite', groupcallback)   client:sethandler('groupresponse', groupcallback)   while run do     client:step()   end end local function datacallback(data)   -- ignore ping messages   if data == 'ping' then     return   end   data = json.pdecode(data) end local co = ngx.thread.spawn(lbthread, ws) repeat   local data, typ, err = ws:recv_frame()   if typ == 'text' then     datacallback(data)   end until ws.fatal or typ == 'close' or ngx.worker.exiting() ngx.thread.kill(co) if not ws.fatal then   ws:send_close() end
jQuery is required for localbus, but only $.ajax, $.param and $.each functions are used. I suppose you can provide your own compatibility layer if using any other JS library.
Socket.io server on .lp file - by buuuudzik - 18.12.2018, 10:13
RE: Socket.io server on .lp file - by admin - 18.12.2018, 10:54
RE: Socket.io server on .lp file - by admin - 18.12.2018, 12:58
RE: Socket.io server on .lp file - by admin - 18.12.2018, 15:38
RE: Socket.io server on .lp file - by admin - 18.12.2018, 16:57
RE: Socket.io server on .lp file - by admin - 18.12.2018, 19:30
