14.03.2016, 21:14
(14.03.2016, 18:44)Sebastiaan Wrote: Hi everyone,
I linked some IP-cameras with the visualisation in LM4, everything works fine inside the same network as LM. I opened the necessary ports on my router for external access to my visualisation at home. Everything works fine here, except the camerastreams.
To make these streams visual, i use the camera-url function with an internal URL like http://user:password@192.168.0.50/stream1.mjpg.
I think that when i login from outside my own network, this URL is not looked up in the network of LM, but in the client-network.
Anyone experienced this or found a solution for this issue?
Thanks in advance,
Sebastiaan
Belgium
You are using LAN camera addressess instead of external addresses. If you can't make a VPN connection you must add this cameras but with external addresses like your LM.
