31.12.2018, 14:18
(28.12.2018, 16:59)admin Wrote: Blockly was removed because it was nearly the same as writing code, the only difference is that you don't need to know Lua syntax. FBeditor is more or less what PLC users are used to. Keep in mind that due to how FB logic is programmed the resulting code can be sub-optimal.
Thank you very much for your reply.
As I am not accustomed to programming it is a huge difference between programing LUA or using FB. Removing FB also removed a potential customer group, a pretty large one at that.
The FBeditor is good, but much more complicated and even easy operations such as inverting an incoming signal takes programing skill so it is not for ordinarie consumers.
If LM want to be a product for programers then this was the right choice, otherwise it was not.
Sincerely
