Understanding timed scripting
I´m having some problems understanding why my tried timers don´t work as I want them to.
I have these two scripts, in two scheduled scripts:
-- Trigger trig = '3/5/7' -- set 100% max = '3/5/6' -- store scene lagre = '1/4/5' -- get scene hent = '1/4/6' --status status = '3/4/38' -- locking PIRs PIRlock = '1/3/19' -- find required object obj1 = grp.find(trig) -- object exists and current state is "on" if obj1 and obj1.data then grp.write(lagre, 0, dt.uint8) grp.write(max, 100, dt.scale) grp.write(status, 1, dt.bool) grp.write(PIRlock, 1, dt.bool) -- delta is in seconds delta = os.time() - obj1.updatetime -- switch off when timer expires if delta >= 60 * 60 then grp.write(hent, 128, dt.uint8) grp.write(status, 0, dt.bool) grp.write(PIRlock, 0, dt.bool) end end
The first one is to trigger 100% lighting for one hour, for cleaning purposes. It also locks the PIRs, saves the lighting state before setting 100% and sets a status object so we know it is in play.
However, when I activate the script, everything just goes to 100% immediately. If i try to put it in a normal event script, nothing happens when I push the button....
-- group address or name addr1 = '3/5/8' addr2 = '1/1/50' addr3 = '3/5/9' -- find required object obj = grp.find(addr1) -- object exists and current state is "on" if obj and obj.data then grp.write(addr2, 28, dt.scale) grp.write(addr3, true) -- delta is in seconds delta = os.time() - obj.updatetime -- switch off when timer expires if delta >= 6 * 60 then grp.write(addr2, 22, dt.scale) end if delta >= 12 * 60 then grp.write(addr2, 16, dt.scale) end if delta >= 18 * 60 then grp.write(addr2, 10, dt.scale) end if delta >= 24 * 60 then grp.write(addr2, 4, dt.scale) end if delta >= 30 * 60 then grp.write(addr2, 0, dt.scale) grp.write(addr3, false) end end
This last one is for slowly dimming down the lights in a kids room. However, when I activate this script, whenever the lights is turned on normal, it will always dim down and go dark after a while....
What am I missing here..?
Understanding timed scripting - by FatMax - 19.03.2016, 10:13
RE: Understanding timed scripting - by admin - 21.03.2016, 07:17
