Weather service not working anymore?
Another option is to use forecast from http://yr.no
You have to replace URL with the one that corresponds to your location.
require('socket.http') forecast = {} function parsetag(parser, tag, attributes)   if tag == 'time' then     table.insert(forecast, {})   elseif tag == 'symbol' then     forecast[ #forecast ].symbol = attributes.name   elseif tag == 'precipitation' then     forecast[ #forecast ].precipitation = attributes.value   elseif tag == 'windDirection' then     forecast[ #forecast ].wind_direction = attributes.code   elseif tag == 'windSpeed' then     forecast[ #forecast ].wind_speed = attributes.mps   elseif tag == 'temperature' then     forecast[ #forecast ].temperature = attributes.value   elseif tag == 'pressure' then     forecast[ #forecast ].pressure = attributes.value   end end url = 'http://www.yr.no/place/United_Kingdom/England/London/varsel.xml' data, err = socket.http.request(url) if data then   require('lxp').new({     StartElement = parsetag   }):parse(data)   log(forecast) else   alert('Fetch failed: ' .. tostring(err)) end
RE: Weather service not working anymore? - by admin - 30.03.2016, 10:45
