Cancel event-scripts
Here's a complete example with two sequences - one for "on" event, another for "off". 32/1/1 is the object that triggers execution. Delay between each command is fixed at 0.5 seconds. This can be made adjustable via sequence table, but it must not be 0, otherwise sequence thread won't be able to pass control to localbus monitor thread.
if not client then   require('copas')   seqon = {     { address = '1/1/1', value = true },     { address = '32/1/2', value = 42 },     { address = '32/1/3', value = 43 },     { address = '32/1/4', value = 44 },     { address = '32/1/5', value = 45 },   }   seqoff = {     { address = '1/1/1', value = false },     { address = '32/1/2', value = 53 },     { address = '32/1/3', value = 54 },     { address = '32/1/4', value = 55 },     { address = '32/1/5', value = 56 },   }   function eventhandler(event)     if event.dst == '32/1/1' then       local val = busdatatype.decode(event.datahex, dt.bool)       sequence = val and seqon or seqoff       seqpos = 1       copas.wakeup(seqthread)     end   end   client = require('localbus').new()   client:sethandler('groupwrite', eventhandler)   copas.addserver(client.sock, function()     client.sock = copas.wrap(client.sock)     while true do       client:step()     end   end, 1)   seqthread = copas.addthread(function()     copas.sleep(-1) -- put thread to sleep until wakeup is called     while true do       local curr = sequence[ seqpos ]       grp.write(curr.address, curr.value)       seqpos = seqpos + 1       -- end of sequence       if seqpos > #sequence then         copas.sleep(-1)       else         copas.sleep(0.5)       end     end   end) end copas.step()
Cancel event-scripts - by buuuudzik - 08.02.2019, 09:23
RE: Cancel event-scripts - by Daniel - 08.02.2019, 09:53
RE: Cancel event-scripts - by admin - 08.02.2019, 10:24
RE: Cancel event-scripts - by buuuudzik - 08.02.2019, 14:52
RE: Cancel event-scripts - by Daniel - 08.02.2019, 14:56
RE: Cancel event-scripts - by buuuudzik - 08.02.2019, 15:11
RE: Cancel event-scripts - by admin - 10.02.2019, 11:32
RE: Cancel event-scripts - by buuuudzik - 10.02.2019, 12:18
RE: Cancel event-scripts - by admin - 11.02.2019, 12:45
RE: Cancel event-scripts - by JASK - 07.01.2023, 00:14
RE: Cancel event-scripts - by buuuudzik - 11.02.2019, 14:14
RE: Cancel event-scripts - by khalil - 08.01.2023, 07:48
RE: Cancel event-scripts - by admin - 11.02.2019, 15:40
RE: Cancel event-scripts - by apkotelnikov - 12.02.2019, 23:26
RE: Cancel event-scripts - by buuuudzik - 13.02.2019, 07:37
RE: Cancel event-scripts - by admin - 13.02.2019, 07:49
RE: Cancel event-scripts - by admin - 09.01.2023, 07:49
RE: Cancel event-scripts - by JASK - 30.01.2023, 22:56
RE: Cancel event-scripts - by admin - 31.01.2023, 07:50
