Azure IoT Hub - MQTT
(07.02.2019, 09:04)administración Wrote: Here'se a scheduled script that forms a JSON-encoded string with object values and then pushes them to Azure, then disconnects:
require('json') data = json.encode({  obj1 = grp.getvalue('32/1/1'),  obj2 = grp.getvalue('32/1/2'), }) device_id = 'DEV_TEST' broker = 'DEV.azure-devices.net' port = 8883 username = 'DEV.azure-devices.net/DEV_TEST' password = 'SharedAccessSignature ...' mqtt = require('mosquitto') client = mqtt.new(device_id) running = true client.ON_CONNECT = function(stat, code, err)  if stat then    client:publish('devices/' .. device_id .. '/messages/events/', data)  else    log('mqtt connect error', err, code)  end  client:disconnect()  running = false end client:version_set(mqtt.PROTOCOL_V311) client:tls_set('/home/ftp/azure.crt') client:login_set(username, password) res, err = client:connect(broker, port) if not res then  log('mqtt initial connect error', err)  running = false end if res then  while running do    res, err, code = client:loop()    if not res then      if running then        log('mqtt loop error', err, code)      end      break    end  end else  log('mqtt connection failed', err) end
thanks for the info
With this code I could not connect to azureiotcentral.
apps.azureiotcentral.com
Azure IoT Hub - MQTT - by FatMax - 17.12.2018, 23:00
RE: Azure IoT Hub - MQTT - by FatMax - 21.12.2018, 07:52
RE: Azure IoT Hub - MQTT - by admin - 21.12.2018, 08:26
RE: Azure IoT Hub - MQTT - by FatMax - 10.01.2019, 08:26
RE: Azure IoT Hub - MQTT - by admin - 10.01.2019, 09:55
RE: Azure IoT Hub - MQTT - by Sandstrand - 21.05.2019, 09:15
RE: Azure IoT Hub - MQTT - by FatMax - 03.07.2019, 11:47
RE: Azure IoT Hub - MQTT - by FatMax - 10.01.2019, 11:01
RE: Azure IoT Hub - MQTT - by FatMax - 11.01.2019, 18:26
RE: Azure IoT Hub - MQTT - by Duvan2127 - 04.02.2019, 14:10
RE: Azure IoT Hub - MQTT - by admin - 04.02.2019, 14:50
RE: Azure IoT Hub - MQTT - by Duvan2127 - 04.02.2019, 16:00
RE: Azure IoT Hub - MQTT - by admin - 05.02.2019, 07:38
RE: Azure IoT Hub - MQTT - by Duvan2127 - 05.02.2019, 14:35
RE: Azure IoT Hub - MQTT - by admin - 07.02.2019, 09:04
RE: Azure IoT Hub - MQTT - by Duvan2127 - 15.02.2019, 22:20
RE: Azure IoT Hub - MQTT - by admin - 16.02.2019, 07:21
RE: Azure IoT Hub - MQTT - by edgars - 26.02.2019, 09:18
RE: Azure IoT Hub - MQTT - by FatMax - 01.05.2019, 21:26
RE: Azure IoT Hub - MQTT - by admin - 02.05.2019, 06:46
RE: Azure IoT Hub - MQTT - by FatMax - 02.05.2019, 07:22
RE: Azure IoT Hub - MQTT - by admin - 21.05.2019, 09:27
RE: Azure IoT Hub - MQTT - by admin - 03.07.2019, 12:33
RE: Azure IoT Hub - MQTT - by FatMax - 03.07.2019, 13:06
RE: Azure IoT Hub - MQTT - by admin - 03.07.2019, 13:18
RE: Azure IoT Hub - MQTT - by FatMax - 03.07.2019, 17:48
RE: Azure IoT Hub - MQTT - by admin - 04.07.2019, 06:04
RE: Azure IoT Hub - MQTT - by admin - 04.07.2019, 15:17
