http.request more then 1 command in the same session
Erwin is correct. Try logging response headers:
url = ... res, code, hdrs, stat = socket.http.request(url) log(hdrs)
Logged headers should contain "set-cookie" field which then should be parsed and passed as "cookie" header to next request. This post has a similar example though first request is different since login token is in response JSON body: https://forum.logicmachine.net/showthrea...74#pid5774
RE: http.request more then 1 command in the same session - by admin - 19.02.2019, 08:12
