(07.07.2016, 13:34)rocfusion Wrote: Hi,
To group players you need set the uri of each player to the master player. note as you add each player to the group, this takes time to do, which is why there is an sleep added after each player is placed into the group. Once you have groups the players, set their volume then you can set what to play on the master.
One BIG note to point out when you work with SONOS implementation you will need to make sure that ALL sonos players are be configured with a static IP. The only way to do this is use DHCP reservation which is configured for each player in the router.
Event based script
Code:upnpavcmd('192.168.0.24', 1400, 'Stop') upnpavcmd('192.168.0.24', 1400, 'SetVolume', '<Channel>Master</Channel><DesiredVolume>40</DesiredVolume>') uri = '<CurrentURI>x-rincon:RINCON_000E58DC0F3601400</CurrentURI><CurrentURIMetaData/>' upnpavcmd('192.168.0.8', 1400, 'SetAVTransportURI', uri) os.sleep(1) upnpavcmd('192.168.0.9', 1400, 'SetAVTransportURI', uri) os.sleep(1) upnpavcmd('192.168.0.20', 1400, 'SetAVTransportURI', uri) os.sleep(1) upnpavcmd('192.168.0.25', 1400, 'SetAVTransportURI', uri) os.sleep(1) upnpavcmd('192.168.0.8', 1400, 'SetVolume', '<Channel>Master</Channel><DesiredVolume>20</DesiredVolume>') upnpavcmd('192.168.0.9', 1400, 'SetVolume', '<Channel>Master</Channel><DesiredVolume>20</DesiredVolume>') upnpavcmd('192.168.0.20', 1400, 'SetVolume', '<Channel>Master</Channel><DesiredVolume>20</DesiredVolume>') upnpavcmd('192.168.0.25', 1400, 'SetVolume', '<Channel>Master</Channel><DesiredVolume>20</DesiredVolume>') upnpavcmd('192.168.0.24', 1400, 'SnapshotGroupVolume') uri = '<CurrentURI>pndrradio:2496906846458345314?sn=1</CurrentURI>' meta = uri .. '<CurrentURIMetaData><DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r="urn:schemas-rinconnetworks-com:metadata-1-0/" xmlns="urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/"><item id="OOOX2496906846458345314" parentID="0" restricted="true"><dc:title>Rihanna Radio</dc:title><upnp:class>object.item.audioItem.audioBroadcast</upnp:class><desc id="cdudn" nameSpace="urn:schemas-rinconnetworks-com:metadata-1-0/">SA_RINCON3_massimo@massmore.com</desc></item></DIDL-Lite></CurrentURIMetaData>' upnpavcmd('192.168.0.24', 1400, 'SetGroupVolume', '<Channel>Master</Channel><DesiredVolume>40</DesiredVolume>') upnpavcmd('192.168.0.24', 1400, 'SetGroupMute', '<Channel>Master</Channel><DesiredMute>0</DesiredMute>') upnpavcmd('192.168.0.24', 1400, 'SetAVTransportURI', meta) upnpavcmd('192.168.0.24', 1400, 'Play', '<Speed>1</Speed>')
Common Function
Code:function upnpavcmd(host, port, cmd, param) local client, soap, reqs, service, res, err require('socket') client = socket.tcp() client:settimeout(3) -- try connecting to upnp endpoint res, err = client:connect(host, port) if not res then return nil, err end -- guess service name based on command if cmd =='SetGroupVolume' or cmd == 'SetGroupMute' or cmd == 'SnapshotGroupVolume' then service = 'GroupRenderingControl' elseif cmd == 'SetVolume' or cmd == 'GetVolume' or cmd == 'SetMute' or cmd == 'GetMute' then service = 'RenderingControl' else service = 'AVTransport' end -- soap envelope soap = '<s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/">' .. '<s:Body>' .. '<u:' .. cmd .. ' xmlns:u="urn:schemas-upnp-org:service:' .. service .. ':1">' .. '<InstanceID>0</InstanceID>' .. (param or '') .. '</u:' .. cmd .. '>' .. '</s:Body>' .. '</s:Envelope>' -- http request reqs = 'POST /MediaRenderer/' .. service .. '/Control HTTP/1.1\r\n' .. 'CONNECTION: close\r\n' .. 'HOST: ' .. host .. ':' .. port .. '\r\n' .. 'CONTENT-LENGTH: ' .. soap:len() .. '\r\n' .. 'CONTENT-TYPE: text/xml; charset="utf-8"\r\n' .. 'SOAPACTION: "urn:schemas-upnp-org:service:' .. service .. ':1#' .. cmd .. '"\r\n' .. '\r\n' .. soap -- send http request res, err = client:send(reqs) if not res then return nil, err end -- get reply and close connection res, err = client:receive('*a') client:close() return res, err end
thanks,
Roger
Hello everybody,
with me this does not work with the following script unfortunately.
My second Sonos is simply started, but not grouped with the master.
Can anyone help me? is it possible that you can't group Sonos One with Sonos Beam?
upnpavcmd('192.168.2.134', 1400, 'Stop')
upnpavcmd('192.168.2.120', 1400, 'SetVolume', '<Channel>Master</Channel><DesiredVolume>40</DesiredVolume>')
upnpavcmd('192.168.2.120', 1400, 'SetAVTransportURI', uri)
upnpavcmd('192.168.2.120', 1400, 'SetVolume', '<Channel>Master</Channel><DesiredVolume>20</DesiredVolume>')
upnpavcmd('192.168.2.134', 1400, 'SnapshotGroupVolume')
upnpavcmd('192.168.2.134', 1400, 'SetGroupVolume', '<Channel>Master</Channel><DesiredVolume>40</DesiredVolume>')
upnpavcmd('192.168.2.134', 1400, 'SetGroupMute', '<Channel>Master</Channel><DesiredMute>0</DesiredMute>')
upnpavcmd('192.168.2.134', 1400, 'SetAVTransportURI', meta)
upnpavcmd('192.168.2.134', 1400, 'Play', '<Speed>1</Speed>')
