Hue Brightness feedback
#26
Hello, I also have some problems with the feedback of the Hue lamp.
I get the following error message.
Quote:Resident script:22: bad argument #1 to 'decode' (string expected, got table)
stack traceback:
 [C]: in function 'decode'
I suspect the problem is the following line.
  mylamps = json.decode(reply)
could someone take a look at my code?
Is something wrong?
I only have the user.hue in my user library.
-- Set name (Lookup in HUE app under light configuration) and feedback adresses (don't change statevalue, brivalue and colorvalue as they are used as memoryfield) addressmapping = {   -- Name   -- On/Off FB    -- Bright FB   -- Color FB   ['Stehlampe Wohnzimmer'] = {state = '8/4/0', bri = '8/5/0', rgb = '8/2/0', statevalue = '', brivalue = '', colorvalue = ''}, --  ['Hue Küche'] = {state = '1/3/2', bri = '1/4/2', rgb = '1/5/2', statevalue = '', brivalue = '', colorvalue = ''}, --  ['Schalter Wohnzimmer'] = {state = '1/3/3', bri = '1/4/3', rgb = '1/5/3', statevalue = '', brivalue = '', colorvalue = ''}, --  ['Hue Schlafzimmer'] = {state = '1/3/4', bri = '1/4/4', rgb = '1/5/4', statevalue = '', brivalue = '', colorvalue = ''} } -- Set polling interval in seconds interval = 1 -- Use logging logging = true require('user.hue') require('json') -- loop indefenitly while true do   reply = getHueLights()   mylamps = json.decode(reply)      for _, item in pairs(mylamps) do     -- Check if lamp is found by bridge otherwise it make no sense to send commands     if item.state.reachable == true then       log(item.state.reachable)       -- On/Off       name = addressmapping[item.name]       if name then         addr = addressmapping[item.name]['state']         if addr and addr ~= '' then           currentvalue = addressmapping[item.name]['statevalue']           if currentvalue ~= item.state.on then             grp.update(addr, item.state.on)             addressmapping[item.name]['statevalue'] = item.state.on             if logging == true then               log('lamp ' .. item.name .. ' state is: ' .. tostring(item.state.on))             end           end         end       end       -- Brightness       name = addressmapping[item.name]       if name then         addr = addressmapping[item.name]['bri']         if addr and addr ~= '' then           -- Check if lamp is on otherwise overrule BRI value to 0           if item.state.on == false then             item.state.bri = 0           end           currentvalue = addressmapping[item.name]['brivalue']           if currentvalue ~= item.state.bri then             grp.update(addr, math.floor((tonumber(item.state.bri)/2.55) + 0.5))             addressmapping[item.name]['brivalue'] = item.state.bri             if logging == true then               log('lamp ' .. item.name .. ' brightness is: ' .. math.floor((tonumber(item.state.bri)/2.55) + 0.5) .. ' %')             end           end         end       end       -- Color       name = addressmapping[item.name]       if name then         addr = addressmapping[item.name]['rgb']         if addr and addr ~= '' then           -- Check if lamp is on otherwise overrule color value to 0           if item.state.on == false then              colorvalue = 0           end           if item.state.colormode == 'xy' then             currentvalue = addressmapping[item.name]['colorvalue']             colorvalue = xy_to_rgb(item.state.xy[1],item.state.xy[2],item.state.bri)             --colorvalue = xyz_to_rgb((item.state.xy[1] * 100), (item.state.xy[2] * 100))             if currentvalue ~= colorvalue then               grp.update(addr, colorvalue)               addressmapping[item.name]['colorvalue'] = colorvalue               if logging == true then                 log('lamp ' .. item.name .. ' color is: ' .. colorvalue)               end             end           elseif item.state.colormode == 'ct' then             currentvalue = addressmapping[item.name]['colorvalue']             --colortemp = math.floor((item.state.ct / 0.0769) + 0.5)  --0.0769230769230769             colortemp = math.abs((item.state.ct - 500) / 2)             colortemp = math.floor(colortemp + 0.5)             colortemp = 80 + colortemp             if colortemp > 255 then               colortemp = 255             end             r = lmcore.inttohex(255, 1)             g = lmcore.inttohex(255, 1)             b = lmcore.inttohex(colortemp, 1)             rgb = r .. g .. b             colortemp = lmcore.hextoint(rgb,3)             if currentvalue ~= colortemp then               --colortempconverted = ct_to_rgb(colortemp)               grp.update(addr, colortemp)               addressmapping[item.name]['colorvalue'] = colortemp               if logging == true then                 log('lamp ' .. item.name .. ' color is: ' .. colortemp)               end             end           end         end       end            end     --log('manufacturername = ' .. item.manufacturername)     --log('swversion = ' .. item.swversion)     --log('type = ' .. item.type)     --log('ct = ' .. item.state.ct)     --log('reachable = ' .. item.state.reachable)     --log('alert = ' .. item.state.alert)     --log('on = ' .. item.state.on)   --log('bri = ' .. item.state.bri)     --log('colormode = ' .. item.state.colormode)     --log('hue = ' .. item.state.hue)     --log('sat = ' .. item.state.sat)     --log('effect = ' .. item.state.effect)     --log('x = ' .. item.state.xy[1])     --log('y = ' .. item.state.xy[2])     --log('uniqueid = ' .. item.uniqueid)     --log('modelid = ' .. item.modelid)     --log('name = ' .. item.name)   end -- Delay loop os.sleep(interval) end
Hue Brightness feedback - by Arjen Straver - 05.07.2017, 19:30
RE: Hue Brightness feedback - by Hippolyte - 19.07.2017, 15:14
RE: Hue Brightness feedback - by Hippolyte - 27.07.2017, 07:03
RE: Hue Brightness feedback - by Albertor - 21.11.2017, 18:22
RE: Hue Brightness feedback - by Albertor - 22.11.2017, 19:51
RE: Hue Brightness feedback - by DarthPaul - 13.08.2018, 12:19
RE: Hue Brightness feedback - by DarthPaul - 14.08.2018, 04:42
RE: Hue Brightness feedback - by admin - 13.08.2018, 12:40
RE: Hue Brightness feedback - by ralwet - 19.10.2018, 20:28
RE: Hue Brightness feedback - by FatMax - 30.11.2018, 16:36
RE: Hue Brightness feedback - by admin - 30.11.2018, 16:48
RE: Hue Brightness feedback - by FatMax - 01.12.2018, 02:58
RE: Hue Brightness feedback - by admin - 03.12.2018, 07:49
RE: Hue Brightness feedback - by FatMax - 03.12.2018, 07:59
RE: Hue Brightness feedback - by timchan054 - 02.01.2019, 01:13
RE: Hue Brightness feedback - by Daniel - 02.01.2019, 13:05
RE: Hue Brightness feedback - by lenze90 - 24.02.2019, 10:07
RE: Hue Brightness feedback - by Daniel - 25.02.2019, 09:13
RE: Hue Brightness feedback - by Zandkever - 21.08.2019, 09:02
RE: Hue Brightness feedback - by admin - 21.08.2019, 09:22
RE: Hue Brightness feedback - by Zandkever - 21.08.2019, 10:20
RE: Hue Brightness feedback - by Tee_Trinker - 08.05.2020, 22:31
RE: Hue Brightness feedback - by Tee_Trinker - 13.05.2020, 19:47
RE: Hue Brightness feedback - by Firechief - 08.06.2020, 16:16
RE: Hue Brightness feedback - by Firechief - 09.06.2020, 08:24
RE: Hue Brightness feedback - by Ravi Kiran S - 25.03.2021, 10:51
RE: Hue Brightness feedback - by MLa - 30.07.2020, 20:03
RE: Hue Brightness feedback - by MLa - 31.07.2020, 18:05
RE: Hue Brightness feedback - by Sral1987 - 02.08.2020, 17:25
RE: Hue Brightness feedback - by Sral1987 - 09.08.2020, 08:27
RE: Hue Brightness feedback - by Sral1987 - 05.09.2020, 15:48
RE: Hue Brightness feedback - by Sral1987 - 05.09.2020, 16:03
RE: Hue Brightness feedback - by Sral1987 - 01.05.2023, 08:44
RE: Hue Brightness feedback - by Firechief - 08.11.2020, 12:35
RE: Hue Brightness feedback - by admin - 09.11.2020, 08:23
RE: Hue Brightness feedback - by Firechief - 09.11.2020, 15:17
RE: Hue Brightness feedback - by admin - 09.11.2020, 15:45
RE: Hue Brightness feedback - by Firechief - 09.11.2020, 16:24
RE: Hue Brightness feedback - by admin - 09.11.2020, 17:13
RE: Hue Brightness feedback - by Firechief - 09.11.2020, 17:31
RE: Hue Brightness feedback - by admin - 09.11.2020, 17:45
RE: Hue Brightness feedback - by Firechief - 09.11.2020, 18:15
RE: Hue Brightness feedback - by Sral1987 - 27.11.2020, 17:36
RE: Hue Brightness feedback - by admin - 30.11.2020, 07:26
RE: Hue Brightness feedback - by Sral1987 - 30.11.2020, 15:59
RE: Hue Brightness feedback - by Sral1987 - 01.12.2020, 15:21
RE: Hue Brightness feedback - by Karaffe - 21.01.2022, 07:50
RE: Hue Brightness feedback - by Firechief - 25.03.2023, 14:56
RE: Hue Brightness feedback - by admin - 27.03.2023, 05:28
RE: Hue Brightness feedback - by Firechief - 28.03.2023, 07:47
RE: Hue Brightness feedback - by admin - 28.03.2023, 07:58
RE: Hue Brightness feedback - by Firechief - 28.03.2023, 09:31
RE: Hue Brightness feedback - by admin - 28.03.2023, 09:31
RE: Hue Brightness feedback - by Firechief - 28.03.2023, 09:35
RE: Hue Brightness feedback - by admin - 28.03.2023, 09:39
RE: Hue Brightness feedback - by Firechief - 28.03.2023, 09:41
RE: Hue Brightness feedback - by NKereshki - 20.04.2023, 11:32
RE: Hue Brightness feedback - by NKereshki - 20.04.2023, 13:38
RE: Hue Brightness feedback - by NKereshki - 24.04.2023, 06:33
RE: Hue Brightness feedback - by NKereshki - 23.07.2025, 11:31
RE: Hue Brightness feedback - by admin - 23.07.2025, 13:06
RE: Hue Brightness feedback - by NKereshki - 23.07.2025, 13:27
RE: Hue Brightness feedback - by admin - 23.07.2025, 13:38
RE: Hue Brightness feedback - by NKereshki - 23.07.2025, 13:42
RE: Hue Brightness feedback - by admin - 23.07.2025, 13:45
RE: Hue Brightness feedback - by NKereshki - 23.07.2025, 14:16
RE: Hue Brightness feedback - by Daniel - 23.07.2025, 14:25
RE: Hue Brightness feedback - by NKereshki - 24.07.2025, 08:26
RE: Hue Brightness feedback - by admin - 24.07.2025, 08:39
RE: Hue Brightness feedback - by NKereshki - 24.07.2025, 09:14
RE: Hue Brightness feedback - by admin - 24.07.2025, 09:22
RE: Hue Brightness feedback - by NKereshki - 24.07.2025, 12:40
RE: Hue Brightness feedback - by admin - 24.07.2025, 12:54
RE: Hue Brightness feedback - by NKereshki - 24.07.2025, 14:29
RE: Hue Brightness feedback - by Sral1987 - 28.07.2025, 05:45
RE: Hue Brightness feedback - by NKereshki - 28.07.2025, 11:18
RE: Hue Brightness feedback - by admin - 25.07.2025, 07:06
RE: Hue Brightness feedback - by NKereshki - 30.07.2025, 19:27
RE: Hue Brightness feedback - by stianj - 31.07.2025, 09:40
RE: Hue Brightness feedback - by Daniel - 31.07.2025, 07:37
RE: Hue Brightness feedback - by Sral1987 - 01.08.2025, 04:53
