Hue ledstrip with RGB and Tunable white
Add to user library:
function setBrightnessCT(Light_num,brightness,ct)   if brightness == 0 then     body_msg = '{"on":false}'     response = sendToLight(lamp_id,body_msg)     return response   else     brightness = math.floor((brightness / 1) + 0.5)     brightness = math.floor((brightness * 2.54) + 0.5)        ct = math.floor(1000000 / ct)     ct = math.min(500, ct)     ct = math.max(154, ct)     --HTTP request send     body_msg = '{"on":true,"bri":'..brightness..',"ct":'..ct..'}'     return sendToLight(Light_num,body_msg)   end end
You will need to map an event script to both brightness and color temperature values:
require('user.hue) lamp_id = 123 bri = grp.getvalue('1/1/1') -- 0..100% ct = grp.getvalue('1/1/2') -- 2000K..6500K setBrightnessCT(lamp_id, bri, ct)
RE: Hue ledstrip with RGB and Tunable white - by admin - 19.03.2019, 09:13
