CanX input and output on same device not responding
(12.04.2019, 07:40)Daniel. Wrote: Hi
Scan each device and check what is assigned to each object.
When i trigger the switch for input 1, the bus trafic led diode on the "4x10A CanX relay" which is on the same bus is blinking, but not on the UIO8 where the switch is connected. As i posted in picture before i get respons on the monitor when i trigger the input. I can altso manually in LM App set value on output 8 and the output responds like i expect.
Is the UIO8 broken since the diode is not blinking on bus trafic?
Hi.
I have now reset both UIO8 and R4 (reset button on device) and deleted everything in App. I have disconnected the R4 device from the bus. From a blank project i have linked input 1 to output 8. It's the same result as before. I can see activity in monitor, but no respons on output. When i send value 1 or 0 to the group adress the output 8 responds accordingly, and i see type "TX Group" in monitor for the "GroupValueWrite"
RE: CanX input and output on same device not responding - by Kai-Roger - 12.04.2019, 08:15
