Rijndael 128 decrypting?
There are two issues here that cause data errors:
1. aes.lua hashes the secret key
2. PHP uses different padding for secret key and data.
Solution:
1. Use this aes library which supports turning off padding: https://github.com/openresty/lua-resty-s...ty/aes.lua
2. Add library loading as mentioned in this post: https://forum.logicmachine.net/showthrea...7#pid10237
Working example for decrypt:
function pad(str, bits)   local bytes = bits / 8   local rem = #str % bytes   if rem > 0 then     str = str .. string.rep('\0', bytes - rem)   end   return str end encdec = require('encdec') aes = require('aes') key = encdec.base64dec('SsqJ1jifeTA+K1igNwzX9/jx1WDkXGbAY0hiwYTduvc=') data = encdec.base64dec('iKIpbQcvg5kq8Ib9KTrvpAkKy55uh5CET96kqzqGBLWriHG6c2FMiIXrr0NMxr71To7tJvmAWGUlpZtYXmnz/API/PKLsWSMsLBuQEqN63GQZ3kdFOM5eXF0633dsaJ3') hash = { iv = string.rep('\0', 16) } -- no hashing method for key aes_256_ecb, err = aes:new(pad(key, 256), nil, aes.cipher(256, 'ecb'), hash, nil, 0) res = aes_256_ecb:decrypt(pad(data, 128)) -- data block size is always 128 bits log(res)
Rijndael 128 decrypting? - by MichelDeLigne - 24.04.2019, 13:16
RE: Rijndael 128 decrypting? - by admin - 25.04.2019, 07:02
RE: Rijndael 128 decrypting? - by admin - 25.04.2019, 10:20
