Azure IoT Hub - MQTT
#21
(10.01.2019, 09:55)admin Wrote: Thanks!
First, you need to update MQTT library packages:
New CPU:
https://dl.openrb.com/pkg/libmosquitto_1...1_imx6.ipk
https://dl.openrb.com/pkg/luamosquitto_0.3-2_imx6.ipk
Old CPU:
https://dl.openrb.com/pkg/libmosquitto_1.4.15-1_mxs.ipk
https://dl.openrb.com/pkg/luamosquitto_0.3-2_mxs.ipk
Here's a minimal example that you can use, don't forget to change device_id, broker, username and password parameters. You also need to upload azure.crt via FTP (using ftp username, upload to root directory). Certificate file contents: https://gist.github.com/jsopenrb/5873b20...d6b950151f
device_id = 'DEV_TEST' broker = 'DEV.azure-devices.net' port = 8883 username = 'DEV.azure-devices.net/DEV_TEST' password = 'SharedAccessSignature ...' mqtt = require('mosquitto') client = mqtt.new(device_id) client.ON_CONNECT = function(...)  log('ON_CONNECT', ...)  client:publish('devices/' .. device_id .. '/messages/events/', '{id=456}') end client.ON_PUBLISH = function(...)  log('ON_PUBLISH', ...) end client.ON_LOG = function(...)  log('ON_LOG', ...) end client.ON_DISCONNECT = function(...)  log('ON_DISCONNECT', ...) end client:version_set(mqtt.PROTOCOL_V311) client:tls_set('/home/ftp/azure.crt') client:login_set(username, password) client:connect(broker, port) while true do  res, err, code = client:loop()  if not res then    log('loop error', res, err, code)    os.sleep(1)  end end
Is there a typo in the filename or is the package removed from your downloads?
libmosquitto_1.4.15-1_imx6.ipk
Azure IoT Hub - MQTT - by FatMax - 17.12.2018, 23:00
RE: Azure IoT Hub - MQTT - by FatMax - 21.12.2018, 07:52
RE: Azure IoT Hub - MQTT - by admin - 21.12.2018, 08:26
RE: Azure IoT Hub - MQTT - by FatMax - 10.01.2019, 08:26
RE: Azure IoT Hub - MQTT - by admin - 10.01.2019, 09:55
RE: Azure IoT Hub - MQTT - by Sandstrand - 21.05.2019, 09:15
RE: Azure IoT Hub - MQTT - by FatMax - 03.07.2019, 11:47
RE: Azure IoT Hub - MQTT - by FatMax - 10.01.2019, 11:01
RE: Azure IoT Hub - MQTT - by FatMax - 11.01.2019, 18:26
RE: Azure IoT Hub - MQTT - by Duvan2127 - 04.02.2019, 14:10
RE: Azure IoT Hub - MQTT - by admin - 04.02.2019, 14:50
RE: Azure IoT Hub - MQTT - by Duvan2127 - 04.02.2019, 16:00
RE: Azure IoT Hub - MQTT - by admin - 05.02.2019, 07:38
RE: Azure IoT Hub - MQTT - by Duvan2127 - 05.02.2019, 14:35
RE: Azure IoT Hub - MQTT - by admin - 07.02.2019, 09:04
RE: Azure IoT Hub - MQTT - by Duvan2127 - 15.02.2019, 22:20
RE: Azure IoT Hub - MQTT - by admin - 16.02.2019, 07:21
RE: Azure IoT Hub - MQTT - by edgars - 26.02.2019, 09:18
RE: Azure IoT Hub - MQTT - by FatMax - 01.05.2019, 21:26
RE: Azure IoT Hub - MQTT - by admin - 02.05.2019, 06:46
RE: Azure IoT Hub - MQTT - by FatMax - 02.05.2019, 07:22
RE: Azure IoT Hub - MQTT - by admin - 21.05.2019, 09:27
RE: Azure IoT Hub - MQTT - by admin - 03.07.2019, 12:33
RE: Azure IoT Hub - MQTT - by FatMax - 03.07.2019, 13:06
RE: Azure IoT Hub - MQTT - by admin - 03.07.2019, 13:18
RE: Azure IoT Hub - MQTT - by FatMax - 03.07.2019, 17:48
RE: Azure IoT Hub - MQTT - by admin - 04.07.2019, 06:04
RE: Azure IoT Hub - MQTT - by admin - 04.07.2019, 15:17
