14.06.2019, 21:56
(This post was last modified: 14.06.2019, 22:00 by Erwin van der Zwart.)
As sender is “bus” that is not possible in my opinion..
If you are so sure it comes from the controller then you need to check objects if read during startup is checked or if read interval is > 0 and check your scripts and startup script and custom JS (JS can only run when a client is active). Check if any tag is linked to the object that you might have overlooked.
There is no way the controller does this on its own without any cause activated from items above...
Can you disable KNX IP features on the reboot to be sure it does not come from IP somewhere?
