Ping IP doesn't work
I am using this script: https://forum.logicmachine.net/showthread.php?tid=1035 to ping an IP adress of a laptop in the same network as the LM is. It somewhy does not work, I transformed script into this:
function socketping(ip, port, timeout)   port = port or 80   local sock = require('socket').tcp()   sock:settimeout(timeout or 20)   local res, err = sock:connect(ip, port)   log(res)   log(err)   sock:close()     return res, err end ip = '192.168.100.149' if socketping(ip) then   log('CONNECTED')   grp.write('0/0/9', true) else   log('DISCONECTED') end
But it always logs disconected, no matter what I try. If I ping the IP from cmd, it pings fine. Where could be the problem?
Thank You.
Ping IP doesn't work - by MantasJ - 08.08.2019, 07:30
RE: Ping IP doesn't work - by Daniel - 08.08.2019, 07:49
RE: Ping IP doesn't work - by admin - 08.08.2019, 07:49
RE: Ping IP doesn't work - by MantasJ - 08.08.2019, 08:10
RE: Ping IP doesn't work - by Daniel - 08.08.2019, 08:19
RE: Ping IP doesn't work - by MantasJ - 08.08.2019, 08:34
RE: Ping IP doesn't work - by AlexLV - 22.04.2020, 21:23
RE: Ping IP doesn't work - by admin - 23.04.2020, 05:07
RE: Ping IP doesn't work - by AlexLV - 23.04.2020, 08:16
RE: Ping IP doesn't work - by djaval - 24.04.2024, 08:05
RE: Ping IP doesn't work - by admin - 24.04.2024, 08:47
RE: Ping IP doesn't work - by khalil - 30.01.2025, 09:44
RE: Ping IP doesn't work - by admin - 30.01.2025, 11:35
RE: Ping IP doesn't work - by khalil - 30.01.2025, 11:40
RE: Ping IP doesn't work - by admin - 30.01.2025, 11:41
