Ping IP doesn't work
Thank You guys. I've tried the script, but now it always logs that the IP is connected even though it is on another network. I don't understand, if there is something I'm doing wrong? Here is the script:
function ping(ip)   local res = os.execute('ping -c 2 -W 5 ' .. ip)   return res == 0 end ping('192.168.100.222') if ping then   log('Connected')   log(ping)   --grp.checkwrite('0/0/9', true) else   log('Disconected')   --grp.checkwrite('0/0/9', false) end
If I ping this IP from cmd the request times out and it is disconected, but if I run this script it says it is connected. Maybe I have to somehow decode the data from "res"?
This is what logs gives me:
Ping IP 08.08.2019 11:04:40 * string: Connected Ping IP 08.08.2019 11:04:40 * function: 0xb6b9d158
Ping IP doesn't work - by MantasJ - 08.08.2019, 07:30
RE: Ping IP doesn't work - by Daniel - 08.08.2019, 07:49
RE: Ping IP doesn't work - by admin - 08.08.2019, 07:49
RE: Ping IP doesn't work - by MantasJ - 08.08.2019, 08:10
RE: Ping IP doesn't work - by Daniel - 08.08.2019, 08:19
RE: Ping IP doesn't work - by MantasJ - 08.08.2019, 08:34
RE: Ping IP doesn't work - by AlexLV - 22.04.2020, 21:23
RE: Ping IP doesn't work - by admin - 23.04.2020, 05:07
RE: Ping IP doesn't work - by AlexLV - 23.04.2020, 08:16
RE: Ping IP doesn't work - by djaval - 24.04.2024, 08:05
RE: Ping IP doesn't work - by admin - 24.04.2024, 08:47
RE: Ping IP doesn't work - by khalil - 30.01.2025, 09:44
RE: Ping IP doesn't work - by admin - 30.01.2025, 11:35
RE: Ping IP doesn't work - by khalil - 30.01.2025, 11:40
RE: Ping IP doesn't work - by admin - 30.01.2025, 11:41
