API with Mitsubishi MELCloud for heatingpumps
Here's a working example, it will log all devices from your account.
email = 'test@test.com' password = '123456' https = require('ssl.https') json = require('json') ltn12 = require('ltn12') function encodepost(t)   local res = {}   local esc = require('socket.url').escape   for k, v in pairs(t) do     res[ #res + 1 ] = esc(k) .. '=' .. esc(v)   end   return table.concat(res, '&') end function login(email, password)   local url = 'https://app.melcloud.com/Mitsubishi.Wifi.Client/Login/ClientLogin'   local data = encodepost({     AppVersion = '1.9.3.0',     Language = '7',     CaptchaChallenge = '',     CaptchaResponse = '',     Persist = 'true',     Email = email,     Password = password,   })   local res, code = https.request(url, data)   if res then     resp = json.pdecode(res)     if type(resp) ~= 'table' then       return nil, 'failed to decode reply data'     elseif resp.ErrorId ~= json.null then       return nil, 'cloud login failed'     else       return resp.LoginData.ContextKey     end   else     return nil, 'login request failed'   end end function getdevices(key)   local url = 'https://app.melcloud.com/Mitsubishi.Wifi.Client/User/ListDevices'   local tbl = {}   local res, code = https.request({     url = url,     headers = {       ['X-MitsContextKey'] = key     },     sink = ltn12.sink.table(tbl),   })   if res then     local data = table.concat(tbl)     return json.pdecode(data)   else     return nil, 'get devices request failed'   end end key, err = login(email, password) if key then   items, err = getdevices(key)   if items then     for _, item in ipairs(items) do       local devs = item.Structure.Devices       for _, dev in ipairs(devs) do         log(dev)       end     end   else     log(err)   end else   log(err) end
RE: API with Mitsubishi MELCloud for heatingpumps - by admin - 12.08.2019, 10:23
