MQTT Secure Websocket - FATAL Unknown CA
(06.09.2019, 09:04)admin Wrote: You need to provide full certificate chain in a single file including root certificate (DST Root CA X3). It is not supplied by default because it usually can be found in system's ca-certificates storage. Since LM does not have any ca-certificates by default you need to have all certificates in a single file.
Hi admin, thank you for your reply, the error is gone but I now notice, using wireshark, the TLS handshake repeatedly succeeds on every step, the server decodes application data as being 'mqtt' but after the final step there's a connection reset every time....
Why would the connection get constantly reset?
See attached screenshot
Greetings,
RE: MQTT Secure Websocket - FATAL Unknown CA - by ThomasB - 06.09.2019, 14:42
