1-wire DS18B20 change resolution
(17.05.2016, 08:10)gjniewenhuijse Wrote:
(17.05.2016, 08:02)admin Wrote: You can read 12-bit result via a script but there's no big point in doing that. Even though theoretical resolution is better the resulting value won't be stable due to how the measurement works. The better approach is to do over-sampling by averaging the resulting values over a specific period of time.
Oke, but i like to have my values with 0,1 precision.
With a arduino and the same type sensor i can do this, but connected to the LM4 it gives strange results: see attached picture.
You can add an event-based script which repeat this value with custom precision or you can use custom values for visualisation if this is only for visualisation purposes.
RE: 1-wire DS18B20 change resolution - by buuuudzik - 17.05.2016, 08:13
