SQL challenge yet again
(20.09.2019, 12:02)Daniel. Wrote: You will have quite a lot of logs there Wink
Yep, I used it during debugging and forgot to remove it :-)
It is no longer there in my live script.
Updated version, now as function so that one can add several ranges to delete.
Now without extensive logging  Smile
function deleteGA(start, stop)     startHG = tonumber(string.split(start, '/')[1])     startMG = tonumber(string.split(start, '/')[2])     startUG = tonumber(string.split(start, '/')[3])          startID = (startHG * 2048) + (startMG * 256) + startUG               stopHG = tonumber(string.split(stop, '/')[1])     stopMG = tonumber(string.split(stop, '/')[2])     stopUG = tonumber(string.split(stop, '/')[3])          stopID = (stopHG * 2048) + (stopMG * 256) + stopUG          if stopID < startID then       log('Start has higher value than stop. Delete is not possible')     else       log('Addresses within range are deleted')       adresser = db:getall('SELECT address, name FROM objects WHERE ID BETWEEN "' .. startID .. '" AND  "' .. stopID .. '"')       for _, addr in ipairs(adresser) do         --log(addr.name)         grp.delete(addr.name)       end     end end start = '26/0/0' stop = '26/0/10' deleteGA(start, stop) start = '26/0/51' stop = '26/0/70' deleteGA(start, stop)
SQL challenge yet again - by Trond Hoyem - 16.09.2019, 13:31
RE: SQL challenge yet again - by Daniel - 16.09.2019, 14:25
RE: SQL challenge yet again - by admin - 16.09.2019, 18:50
RE: SQL challenge yet again - by Trond Hoyem - 17.09.2019, 19:43
RE: SQL challenge yet again - by Trond Hoyem - 20.09.2019, 12:00
RE: SQL challenge yet again - by Daniel - 20.09.2019, 12:02
RE: SQL challenge yet again - by Trond Hoyem - 20.09.2019, 12:09
RE: SQL challenge yet again - by Trond Hoyem - 25.09.2019, 06:33
