1-wire DS18B20 change resolution
Here's a function you can use to calculate the average, this version will keep last count values and will returnt the average for every insert:
function avg(store, count, value)   local sum = 0   -- add new value as first (newest) store element   table.insert(store, 1, value)   -- remove old elements, until store size is correct   while #store > count do     table.remove(store)   end   -- calucate value sum   for _, value in ipairs(store) do     sum = sum + value   end   -- get average value   return sum / #store end
And here's how you can use it:
if not store then   require('ow')   -- load avg function here   store = {} end value = ow.readfile('28.690E0A070000', 'temperature', true) avgvalue = avg(store, 5, value)
You can add an extra counter in your resident script if you want to send a new value for each X samples.
RE: 1-wire DS18B20 change resolution - by admin - 17.05.2016, 12:47
