Help me! Notification SMS from LM using Twilio service
(11.10.2019, 06:52)admin Wrote: You have swapped from/to fields. It should be:
sms(id_nr, token_nr, from_nr, to_nr, 'Test SMS by SL'..tostring(value))
Same trouble Sad
My Common Funtions:
--SMS by Twilio function sms(id, token, from, to, body)   local escape = require('socket.url').escape   local request = require('ssl.https').request   local url = string.format('https://%s:%s@api.twilio.com/2010-04-01/Accounts/%s/Messages.json', id, token, id)   local body = string.format('From=%s&To=%s&Body=%s', escape(from), escape(to), escape(body))   return request(url, body) end
My Event:
value = event.getvalue() from_nr = '+19177461563' -- put sender SIM nr here to_nr = '+84938354162' -- put recepient SIM nr here id_nr = '...' -- put your ID here token_nr = '...' -- put your token here sms(id_nr, token_nr, from_nr, to_nr, 'Test SMS by SL'..tostring(value))
RE: Help me! Notification SMS from LM using Twilio service - by cuong.nguyen@vis.solutions - 15.10.2019, 01:24
