Resident script stops working
What would stop a resident script from running`?
I've got several resident scripts that sometimes just stop running, it shows active in script listing, but according to Processes app it does not run.
Works like normal after turning it off and on again.
Nothing appears in error logs.
This is the script most commonly to stop working, i've checked many times that all all GA's have set values like they should etc.
Output = 'scene mainbedroom' outputvalue = 13 countdown = 'cd time mainbedroom' mode = grp.getvalue('lightmode mainbedroom') updatetime = storage.get('movement_mb', 0) delta = os.time() - updatetime pir_active = grp.getvalue('pir mainbedroom') if pir_active == false then   script.disable(_SCRIPTNAME) end cdactive = false if mode == 1 then   runtime = grp.getvalue('rt_m_mainbedroom') elseif mode == 2 then   runtime = grp.getvalue('rt_d_mainbedroom') elseif mode == 3 then   runtime = grp.getvalue('rt_e_mainbedroom') elseif mode == 4 then   runtime = grp.getvalue('rt_l_mainbedroom') elseif mode == 5 then   runtime = 5 end if outputvalue == grp.getvalue(output) then   if cdactive == true then     grp.update(countdown, 0)   end   script.disable(_SCRIPTNAME) end if cdactive == true then   timeleft = (runtime * 60) - delta   grp.update(countdown, timeleft) end -- turn off when timer expires if delta >= (runtime * 60) then   grp.write(output, outputvalue)   if cdactive == true then     grp.update(countdown, 0)   end   script.disable(_SCRIPTNAME) end if pir_active == false then   script.disable(_SCRIPTNAME) end
Best regards, Jørn.
Resident script stops working - by Jørn - 16.10.2019, 13:21
RE: Resident script stops working - by Jørn - 16.10.2019, 13:57
RE: Resident script stops working - by admin - 16.10.2019, 14:23
RE: Resident script stops working - by Jørn - 16.10.2019, 15:02
