Energy Management by Wiser
Work with EER31600, with EER31800 don't knwo ?
in user library
WiserLinkIP.lua
-- ******************************************** -- --               SCHNEIDER ELECTRIC             -- --                                              -- -- Author : Valentin THOMAS                     -- -- Version : 1.0                                -- -- Update Date : 17/10/2017                     -- -- Name : WISER_LINK.lua                        -- --                                              -- -- ******************************************** -- WISER_LINK = function ()   local self = {script={}}   local debug = false   local history = false   local json = require('json')   local http = require("socket.http")   -- -------------------------------------------------------------------   --- This function   -- @param (none)   --   -- @return (none)   function round(nb)     i,f=math.modf(nb)     return i+(math.ceil(f/0.0625)*0.0625)   end   -- -------------------------------------------------------------------   --- This function   -- @param (none)   --   -- @return (none)   function self.getData(_ip, _login, _password)         local wiser_data = {}     local datas, http_code, header, err = http.request("http://".._login..":".._password.."@".._ip.."/vesta/UsageMeter")         --Si le code HTTP de la réponse est 200     if http_code == 200 then       if not datas then         error('Cannot fetch data at : '..ip_address)           else                   local datas=json.decode(datas)         for index,usage in pairs (datas.UsageMeterList)do                       usage_name=string.gsub(usage.Type," ","_")--Remplacement de l'espace par un underscore           wiser_data["Power_"..usage_name]=round(usage.Power)           wiser_data["Energy_"..usage_name]=round(usage.EnergyConsumed)                   end               end             else       msg=string.format("Error in HTTP request, code:%s, Message:%s",http_code,err)               error(msg)       log(msg)       alert(msg)     end   end   -- -------------------------------------------------------------------   --- This function   -- @param (none)   --   -- @return (none)   function self.script.event(event, _params)   end   -- -------------------------------------------------------------------   --- This function   -- @param (none)   --   -- @return (none)   function self.script.cycle( _params )   end   -- -------------------------------------------------------------------   --- This function   -- @param (none)   --   -- @return (none)   function self.script.scheduler( _params )       end     return self end class_var =  WISER_LINK() return class_var -- CODE POUR SCRIPTS CLIENT --[[ WISER_LINK = require('user.WISER_LINK') params = {   tag_name = 'record',              -- tag to add to each knx object to record   records_delay = 1,                -- delay between 2 records in minutes   records_limit = 50000,            -- limit of the sql table (adviced 50 000 - 10% de la mémoire)   export_delay = 60,                -- delay between 2 exports on usb key in minutes   export_value_separator  = ';',    -- name of the export file on the usb key   export_line_separator = '\r\n',   -- name of the export file on the usb key   export_file_name = 'log.csv'      -- name of the export file on the usb key } ]]--
cycling script:
nb_compt = 6 DEBUG = true require('user.WiserLinkIP') --[[ Description du nom des usages Hot_Water = Eau Chaude Sanitaire Cooling = Refroidissement Heating = Chauffage Sockets = Prises Others = Autres Electricity_Meter = Total issu du TIC ]]-- ADD_IP="192.168.1.11" -- Adresse IP du module Wiser Link IP PORT=80 --Précision d'un numero de port si NAT sinon laisser 80 LOGIN="admin"--Login PASS="admin"--Mot de passe if not my_wiser then   my_wiser=WiserLinkIP.new(ADD_IP..":"..PORT,LOGIN,PASS) end -- Récupération des données depuis le module Wiser Link IP -- Le rafraichissment est basé sur le temps de cycle du présent script my_wiser:fetchDatas() --Rafraichissment des valeurs sur KNX/IP --log(my_wiser) -- UPDATE KNX VARIABLES -- Energies grp.update('6/0/1', my_wiser.Energy_Heating)     --Chauffage grp.update('6/0/2', my_wiser.Energy_Sockets)     --Prises grp.update('6/0/3', my_wiser.Energy_Electricity_Meter) --Total grp.update('6/0/4', my_wiser.Energy_Hot_Water)     --Eau Chaude grp.update('6/0/5', my_wiser.Energy_Others)     --Autre grp.update('6/0/6', my_wiser.Energy_Cooling)     --Eau Froide -- Puissances --grp.update('6/1/0',my_wiser.Power_Sockets) --grp.update('8/2/2',my_wiser.Power_Hot_Water) --grp.update('8/2/3',my_wiser.Power_Heating) --grp.update('8/2/4',my_wiser.Power_Cooling) --grp.update('8/2/5',my_wiser.Power_Electricity_Meter) --grp.update('8/2/6',my_wiser.Power_Others)
SE ECO EXPERT
Energy Management by Wiser - by baggins - 23.03.2019, 14:40
RE: Energy Management by Wiser - by baggins - 23.03.2019, 18:24
RE: Energy Management by Wiser - by AlexLV - 24.03.2019, 06:26
RE: Energy Management by Wiser - by AlexLV - 26.03.2019, 07:09
RE: Energy Management by Wiser - by Daniel - 14.07.2019, 09:23
RE: Energy Management by Wiser - by domotiqa - 24.10.2019, 14:20
RE: Energy Management by Wiser - by stemic01 - 13.01.2021, 19:51
RE: Energy Management by Wiser - by Daniel - 14.01.2021, 08:36
RE: Energy Management by Wiser - by stemic01 - 14.01.2021, 11:45
RE: Energy Management by Wiser - by Daniel - 14.01.2021, 12:29
RE: Energy Management by Wiser - by Daniel - 09.01.2023, 10:20
RE: Energy Management by Wiser - by AlexLV - 11.01.2023, 23:12
RE: Energy Management by Wiser - by domotiqa - 25.08.2023, 14:04
