Curl Request to Lua
Due to the changes of apixu doing their new api, I want to implement another API from our local provider in Switzerland (https://developer.srgssr.ch/content/quickstart-guide).
Curl-Request is working. But I do struggle implementing the Curl-Call in Lua.
Working Curl:
curl -v -X POST 'https://api.srgssr.ch/oauth/v1/accesstoken?grant_type=client_credentials'   \ -H 'Authorization: Basic RFJNblFyV1lpRnN3VGVyS1pOVWpJUzFOQ00WDhHUzU6THlsMG5udGdoMXo2VWxxeg=='   \ -H 'Cache-Control: no-cache'   \ -H 'Content-Length: 0'   \ -H 'Postman-Token: 24264e32-2de0-f1e3-f3f8-eab014bb6d76'
The Curl-Request returns successfully a new bearer access-Token. Verbose-Response from Curl:
*   Trying 3.120.59.111... * TCP_NODELAY set * Connected to api.srgssr.ch (3.120.59.111) port 443 (#0) * ALPN, offering h2 * ALPN, offering http/1.1 * successfully set certificate verify locations: *   CAfile: /etc/ssl/certs/ca-certificates.crt   CApath: /etc/ssl/certs * TLSv1.3 (OUT), TLS handshake, Client hello (1): * TLSv1.3 (IN), TLS handshake, Server hello (2): * TLSv1.2 (IN), TLS handshake, Certificate (11): * TLSv1.2 (IN), TLS handshake, Server key exchange (12): * TLSv1.2 (IN), TLS handshake, Server finished (14): * TLSv1.2 (OUT), TLS handshake, Client key exchange (16): * TLSv1.2 (OUT), TLS change cipher, Client hello (1): * TLSv1.2 (OUT), TLS handshake, Finished (20): * TLSv1.2 (IN), TLS handshake, Finished (20): * SSL connection using TLSv1.2 / ECDHE-RSA-AES256-GCM-SHA384 * ALPN, server accepted to use http/1.1 * Server certificate: *  subject: OU=Domain Control Validated; CN=*.api.srgssr.ch *  start date: Oct 21 15:11:03 2019 GMT *  expire date: Oct 21 08:04:26 2021 GMT *  subjectAltName: host "api.srgssr.ch" matched cert's "api.srgssr.ch" *  issuer: C=US; ST=Arizona; L=Scottsdale; O=GoDaddy.com, Inc.; OU=http://certs.godaddy.com/repository/; CN=Go Daddy Secure Certificate Authority - G2 *  SSL certificate verify ok. > POST /oauth/v1/accesstoken?grant_type=client_credentials HTTP/1.1 > Host: api.srgssr.ch > User-Agent: curl/7.58.0 > Accept: */* > Authorization: Basic RFJNblFyV1lpRnN3VGVyS1pOVWpJUzFOQU00WDhHUzU6THlsMG5udGdoMXo2VWxxeg== > Cache-Control: no-cache > Content-Length: 0 > Postman-Token: 24264e32-2de0-f1e3-f3f8-eab014bb6d76 > < HTTP/1.1 200 OK < Date: Sat, 16 Nov 2019 13:47:37 GMT < Content-Type: application/json < Content-Length: 546 < Connection: keep-alive < Access-Control-Allow-Origin: < Access-Control-Allow-Headers: origin, x-requested-with, accept, content-type, Authorization < Access-Control-Max-Age: 3628800 < Access-Control-Allow-Methods: GET < {   "refresh_token_expires_in" : "0",   "api_product_list" : "[SRG-SSR-PUBLIC-API-V2]",   "api_product_list_json" : [ "SRG-SSR-PUBLIC-API-V2" ],   "organization_name" : "srgssr",   "developer.email" : "s@ss.ch",   "token_type" : "BearerToken",   "issued_at" : "1573912057331",   "client_id" : "DRMnQrWYiSswTerKZNUDIS1NAM4XwGS5",   "access_token" : "MATOKvdJZLtjJy6EyjlAKm7Tk7Zu",   "application_name" : "7c0dd30c-70a0-494f-b9b0-ed7c0b704fad",   "scope" : "",   "expires_in" : "2591999",   "refresh_count" : "0",   "status" : "approved" * Connection #0 to host api.srgssr.ch left intact
Now my Code in Lua:
require('json') require('ssl.https') require('ltn12') require('encdec') local response_body = {} local request_body = "" local body, code, hdrs, stat = ssl.https.request({   url = 'https://api.srgssr.ch/oauth/v1/accesstoken?grant_type=client_credentials',   sink = ltn12.sink.table(response_body),   method = 'POST',   headers = {     ["Authorization"] = "Basic RFJNblFyV1lpRnN3VGVyS1pOVWpJUzFOQ00WDhHUzU6THlsMG5udGdoMXo2VWxxeg==",     ["Cache-Control"] = "no-cache",     ["Content-Length"] = 0,     ["Postman-Token"] = "24264e32-2de0-f1e3-f3f8-eab014bb6d76"   },   source = ltn12.source.string(request_body) }) log(body) log(code) log(hdrs) log(stat)
Logs are returning
body: * nil code: * string: closed hdrs: * nil stat: * nil
Can anybody see, why my Lua-Call is failing with "* nil"?
Thank you! Smile
Curl Request to Lua - by ralwet - 16.11.2019, 13:58
RE: Curl Request to Lua - by admin - 16.11.2019, 15:24
RE: Curl Request to Lua - by ralwet - 16.11.2019, 15:49
