Status feedback from script in LUA [SOLVED]
A quick update on the matter. Maybe other members of the community having similar request….
I have just played a bit around with scripting after the excellent input from LM team and I know found a solution to my quest. I am not 100% sure if I did this by the book, but it seems to work pretty well during my testing.
SCOPE - WHAT I WANTED TO ACHIEVE:
- Rise Morning temperature:
When mode/scene is set to "night", rise the temperature 2 degrees at a given time in the morning (Scheduled script. Not IF in "away", "travel" or "home" mode).
- Lower Night temperature:
When mode/scene is set to "home" or "away" lower the night temperature (Not while in "night" or "travel" mode as the temperature is already set low in these modes)
- Visual scene detection
i also wanted a text in "Touch" which show which "mode/scene" is activated in the house. Very nice to actualy see the feedback on a screen or when operated remotely.
Other:
Later I can integrate other systems that can behave according to status of the house. Dimmed lights at bathroom at night. alarms, ventilation system etc.
HOW:
1. Dedicated Group addresses for "status"
First I made a New Group address for each of my per now 4-scenes/modes (Travel, away, home, night) and set these to be bolean (false/true)
I also made a New Group address for text ASCII-14 for a text Version of the status.
In total 5 New Group addresses
2. Change values (Event based script)
In each scene I have a script write a New value (false/true) to each of my 4 modes (grp.write).
And also set a text to the ascii Group address (Home, Away, Travel, Night) as text.
Everytime this script (home, away, travel, night) for the scene is triggered - the values are updated accordingly from the script in each scene.
3. Scheduled script
In the scheduled scripts I made a New scheduled script for "morning temp" and one for "night temp" at a give time.
Script is checking status of the "scene/mode" and setting the correct morning/night temperature if the certain criteria is met (IF than grp.write, value).
4. Touch:
And in touch I set up a widget showing the text and using status to show which scene is active.
As said - so far it is working well. Not 100% sure if it is by the book. Good Learning process and not too complicated.
Feel free to ask if you need any script examples.
HEATING:
The heating are A) Electrical floor heating for some rooms and a B) Panasonic CS-Z35 heat pump (AC) Connected to my Wiser through KNX Gateway from Intesisbox.
RE: Status feedback from script in LUA - by stemic01 - 08.12.2019, 13:43
