Find and Replace script
I am trying to create a script that can find a certain text inside the object name and replace it with another string. This is so I do not need to do this manually every time there is a large change.
For normal GA I would just use the update from ESF-file solution, but I often have a lot of virtual addresses as well, and they also must be updated.
I am able to find the adresses to update, and to generate the new name, but for some reason I am not able to update the name of the object. If anyone has an idea of why, please give me a hint.
The code I have entered is as follows;
finn = '360.001' replace = '360.002' kriterie = '08-0' liste = db:getall('SELECT name FROM objects WHERE name LIKE "%'.. kriterie .. '%" AND name LIKE "%'.. finn .. '%"') -- for _, name in ipairs(liste) do   navn = name.name   --log(navn)   if string.find(navn, finn, 1, true) == nil then     log('fikk nil')   else     log('fant strengen')     newName = string.gsub(navn, finn, replace)     log(navn, newName)     ga = grp.find(navn)     --db:update('objects', { name = newName }, { id = id })     --log(ga)     address = grp.create({         address = ga.address,         name = newName,       })   end   end log('Ferdig') script.disable(_SCRIPTNAME)
I am sorry for Norwegian names in variables, but that makes it more easy to prevent using a word that has a LUA-meaning....
Find and Replace script - by Trond Hoyem - 10.01.2020, 10:52
RE: Find and Replace script - by admin - 10.01.2020, 12:48
RE: Find and Replace script - by Trond Hoyem - 10.01.2020, 13:06
RE: Find and Replace script - by admin - 10.01.2020, 13:35
RE: Find and Replace script - by Trond Hoyem - 10.01.2020, 13:53
RE: Find and Replace script - by admin - 10.01.2020, 14:06
RE: Find and Replace script - by Trond Hoyem - 10.01.2020, 14:10
