shell script to LUA
Thanks I looked an example! Here is the result:
require('socket.http') socket.http.TIMEOUT = 5 data = "{'username':'user', 'password':'12345'}" url1 = 'https://10.10.11.2:8443/api/login' url2 = 'https://10.10.11.2:8443/api/s/default/stat/sta' res, err, hdrs = socket.http.request(url1,data) if res then   tbl = {}   res, err = socket.http.request({     url = url2,     headers = {       cookie = hdrs['set-cookie']     },     sink = ltn12.sink.table(tbl),   })   if res then     resp = table.concat(tbl)     log(resp)   else     alert('request 2 failed: ' .. tostring(err))   end else   alert('request 1 failed: ' .. tostring(err)) end
But it still gives an error.
* string: {"meta":{"rc":"error","msg":"api.err.LoginRequired"},"data":[]}
I am not good at scripts, may you help me ?
Thanks a lot!
shell script to LUA - by edos - 03.02.2020, 23:31
RE: shell script to LUA - by admin - 04.02.2020, 07:48
RE: shell script to LUA - by edos - 04.02.2020, 18:03
RE: shell script to LUA - by admin - 05.02.2020, 07:31
RE: shell script to LUA - by edos - 05.02.2020, 08:53
RE: shell script to LUA - by admin - 05.02.2020, 09:21
RE: shell script to LUA - by edos - 05.02.2020, 11:30
RE: shell script to LUA - by admin - 05.02.2020, 12:11
RE: shell script to LUA - by benanderson_475 - 23.03.2020, 02:03
RE: shell script to LUA - by admin - 23.03.2020, 07:14
