Telegram bot API
I have used Domoticatorino's Telegram script for a couple of years without problem, but recently it started to fail.
When I call the function I have the following result:
test_telegram 09.02.2020 23:41:30 * string: status: nil test_telegram 09.02.2020 23:41:30 * string: headers: nil test_telegram 09.02.2020 23:41:30 * string: code: revcd alert fatal error test_telegram 09.02.2020 23:41:30 * string: res: nil
I can run the same script on my desktop machine and there it runs without errors...
Any idea what may be going on?
Update: I have tested this on another LM4 where the function is also in use and there the script does not work anymore either.
I also moved the code of the function to the test script, so I don't need a library call, with the same result.
Firmware: 20160714
Telegram bot API - by Domoticatorino - 18.10.2016, 11:49
RE: Telegram bot API - by Erwin van der Zwart - 18.10.2016, 15:35
RE: Telegram bot API - by Domoticatorino - 18.10.2016, 21:23
RE: Telegram bot API - by Erwin van der Zwart - 19.10.2016, 08:36
RE: Telegram bot API - by Domoticatorino - 19.10.2016, 09:22
RE: Telegram bot API - by Erwin van der Zwart - 19.10.2016, 09:33
RE: Telegram bot API - by Domoticatorino - 27.10.2016, 12:05
RE: Telegram bot API - by admin - 27.10.2016, 13:05
RE: Telegram bot API - by Domoticatorino - 27.10.2016, 21:23
RE: Telegram bot API - by Domoticatorino - 15.11.2016, 12:20
RE: Telegram bot API - by DGrandes - 05.09.2018, 16:19
RE: Telegram bot API - by baggins - 09.02.2020, 22:52
RE: Telegram bot API - by admin - 10.02.2020, 06:40
RE: Telegram bot API - by baggins - 10.02.2020, 07:53
RE: Telegram bot API - by admin - 10.02.2020, 08:22
RE: Telegram bot API - by baggins - 10.02.2020, 09:08
RE: Telegram bot API - by Dario - 19.03.2020, 18:43
RE: Telegram bot API - by admin - 19.03.2020, 18:48
RE: Telegram bot API - by Dario - 20.03.2020, 09:48
RE: Telegram bot API - by JRP - 12.05.2020, 18:06
