Telegram bot API
You are using outdated firmware where SSLv3 is used by default. It is disabled on most servers and you have to use TLSv1.2 or newer. Try using this function to make HTTPS GET request:
function request(url)   local resp = {}   local stat, code, hdrs = require('ssl.https').request({     method = 'GET',     url = url,     protocol = 'tlsv12',     sink = ltn12.sink.table(resp),   })   if stat then     stat = table.concat(resp)   end   return stat, code, hdrs end
Telegram bot API - by Domoticatorino - 18.10.2016, 11:49
RE: Telegram bot API - by Erwin van der Zwart - 18.10.2016, 15:35
RE: Telegram bot API - by Domoticatorino - 18.10.2016, 21:23
RE: Telegram bot API - by Erwin van der Zwart - 19.10.2016, 08:36
RE: Telegram bot API - by Domoticatorino - 19.10.2016, 09:22
RE: Telegram bot API - by Erwin van der Zwart - 19.10.2016, 09:33
RE: Telegram bot API - by Domoticatorino - 27.10.2016, 12:05
RE: Telegram bot API - by admin - 27.10.2016, 13:05
RE: Telegram bot API - by Domoticatorino - 27.10.2016, 21:23
RE: Telegram bot API - by Domoticatorino - 15.11.2016, 12:20
RE: Telegram bot API - by DGrandes - 05.09.2018, 16:19
RE: Telegram bot API - by baggins - 09.02.2020, 22:52
RE: Telegram bot API - by admin - 10.02.2020, 06:40
RE: Telegram bot API - by baggins - 10.02.2020, 07:53
RE: Telegram bot API - by admin - 10.02.2020, 08:22
RE: Telegram bot API - by baggins - 10.02.2020, 09:08
RE: Telegram bot API - by Dario - 19.03.2020, 18:43
RE: Telegram bot API - by admin - 19.03.2020, 18:48
RE: Telegram bot API - by Dario - 20.03.2020, 09:48
RE: Telegram bot API - by JRP - 12.05.2020, 18:06
