18.02.2020, 11:11
I'm not sure that it will work. Normal M-bus is master-slave where gateway is a master (including power supply) and each meter is a slave. Your meter only uses M-bus physical layer. The meter is sending data over M-bus periodically. This means that you can connect any number of receivers but only one meter to a single bus. In normal M-bus you need to request data from meters so several meters can share a single bus.
