SpaceLynk and Wiser For Knx BACnet release
(20.02.2020, 20:20)Daniel. Wrote: The SD card is most likely in read only mode and has to be replaced.
ok thank you, I will check the tutorial.
But just a question:
- I can modify the program... (stored in flash ??)
- I didn't have a message in log
EDIT:
I found in system log:
Feb 20 19:44:47 fca-knx kern.info kernel: [ 1.295589] VFS: Mounted root (ext3 filesystem) readonly on device 179:2. Feb 20 19:44:47 fca-knx kern.info kernel: [ 1.295415] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null) Feb 20 19:44:47 fca-knx kern.info kernel: [ 1.293130] EXT4-fs (mmcblk0p2): recovery complete Feb 20 19:44:47 fca-knx kern.info kernel: [ 0.854610] EXT4-fs (mmcblk0p2): write access will be enabled during recovery Feb 20 19:44:47 fca-knx kern.info kernel: [ 0.854553] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly
SE ECO EXPERT
RE: SpaceLynk and Wiser For Knx BACnet release - by domotiqa - 20.02.2020, 20:38
