Doorbird API
Try this resident script (sleep time = 0), change USER and PASS to your auth data. It will log all incoming data (log(line)). This is to check if there are any errors during communication. If everything is working then comment/delete this line.
if not sock then   host = '192.168.100.211'   port = 80   path = '/bha-api/monitor.cgi?ring=doorbell,motionsensor&http-user=USER&http-password=PASS'   sock = require('socket').tcp()   sock:settimeout(10)   res, err = sock:connect(host, port)   if res then     sock:send(       'GET ' .. path .. ' HTTP/1.1\r\n' ..       'Host: ' .. host .. '\r\n\r\n'     )   else     alert('connect failed: ' .. tostring(err))     sock:close()     sock = nil     os.sleep(5)   end end line, err = sock:receive() if line then   log(line)   if line:find('doorbell:') then     status = line:split(':')[2]     log('doorbell', line)   elseif line:find('motionsensor:') then     status = line:split(':')[2]     log('motionsensor', status)   end else   alert('receive failed: ' .. tostring(err))   sock:close()   sock = nil end
Doorbird API - by MantasJ - 10.03.2020, 15:12
RE: Doorbird API - by admin - 10.03.2020, 15:42
RE: Doorbird API - by MantasJ - 10.03.2020, 20:37
RE: Doorbird API - by admin - 11.03.2020, 06:59
RE: Doorbird API - by MantasJ - 11.03.2020, 08:17
RE: Doorbird API - by felixRo - 10.10.2022, 13:48
RE: Doorbird API - by admin - 11.03.2020, 08:57
RE: Doorbird API - by MantasJ - 11.03.2020, 09:17
RE: Doorbird API - by Firechief - 03.07.2020, 17:45
RE: Doorbird API - by Firechief - 13.07.2020, 12:47
RE: Doorbird API - by admin - 13.07.2020, 12:49
RE: Doorbird API - by Firechief - 13.07.2020, 14:21
RE: Doorbird API - by admin - 13.07.2020, 14:28
RE: Doorbird API - by Firechief - 13.07.2020, 14:34
RE: Doorbird API - by admin - 11.10.2022, 09:25
