Set a value when a widget come up
You can use this example. Set Additional classes to widget-open for the element that opens the widget. #widget-2 is widget element id, change it and group address as needed.
Keep in mind that it won't work when transition animation is enabled.
$(function() {   $('.widget-open').on('vclick', function() {     var el = $('#widget-2');     if (el.is(':visible')) {       grp.write('1/1/1', 123);     }   }); });
There will be widget show/hide events added in RC2 firmware that will work correctly with animation:
$(function() {   $('#widget-2').on('widget-show', function() {     grp.write('1/1/1', true);   });      $('#widget-2').on('widget-hide', function() {     grp.write('1/1/1', false);   }); });
RE: Set a value when a widget come up - by admin - 22.03.2020, 14:34
