sound
i try to use below skript for play a sound when i have an alarm , but does not work in alerts i have this message "default page does not excists exit HTMLcreation" no erros ,no logs...
thanks in advance
  1. -- * Audio Alarm Notification Module Version 1.4 Created by Erwin van der Zwart * --
  2. -- * This script perform automaticly all needed actions to support audio alerts * --
  3. --  After running script once refresh browser and write value to object for audio --
  4. -- ******************************** SET PARAMETERS ****************************** --
  5.
  6. -- Group address to trigger the alarm notification
  7. Audio_Trigger_Group_Address = '1/1/1' -- !! MUST BE A BIT OBJECT !!
  8.
  9. -- Audio on value 0 and value 1 or on value 1 only
  10. Audio_on_value_1_only = true -- Set to true for audio on value 1 only
  11.
  12. -- Stop audio on value 0 (used only when Audio_on_value_1_only = true)
  13. Stop_on_value_0 = true -- Set to false to play complete audio file when receiving value 0
  14.
  15. -- Repeat audio until value is 0 (used only when Audio_on_value_1_only = true and Stop_on_value_0 = true)
  16. Repeat_on_value_1 = true -- Set to true for audio loop until object value is false
  17.
  18. -- Check object value on load of visu to start direct based on object value
  19. Start_On_Load = true -- Set to true for audio on load based on object value
  20.
  21. -- Set interval (in seconds) for audio repeat playing file until mute is pressed (used only when Audio_on_value_1_only = true and Stop_on_value_0 = true)
  22. Audio_Play_Interval_Time = 10 -- Adjust to length of playing file
  23.
  24. -- URL to use for downloading a audiofile to the controller on value 0 (only used / needed when line 8 is set to false)
  25. URL_Audio_File_0 = 'http://https://www.computerhope.com/jargon/m/example.mp3'
  26.
  27. -- URL to use for downloading a audiofile to the controller on value 1
  28. URL_Audio_File_1 = 'https://www.computerhope.com/jargon/m/example.mp3'
  29.
  30. -- !IMPORTANT! internet must be available for the controller to download a file
  31. -- check DNS and default gateway or copy your own audio files to the img / backgrounds
  32. -- folder and name it 'alarm_0.xxx' (format like line 13) and 'alarm_1.xxx' (format like line 13)
  33.
  34. -- Downloaded audio file formaton on value 0 (only used / needed when line 8 is set to false)
  35. Audio_File_Format_0 = 'mp3'
  36.
  37. -- Downloaded audio file formaton on value 1
  38. Audio_File_Format_1 = 'mp3'
  39.
  40. -- Create automaticly iframe with logout.html on startpage
  41. Create_Automatic = true -- Set to false to disable auto create and run script once
  42.
  43. -- Delete HTML alarm function from controller
  44. Delete_HTML = false -- Set to true to delete this function and run script once
  45.
  46. -- ******************************** END PARAMETERS ****************************** --
  47. -- ********************* DON'T CHANGE ANYTHING UNDER THIS LINE ****************** --
  48.
  49. -- Set interval (in seconds) for audio repeat playing file until mute is pressed to milliseconds
  50. Audio_Play_Interval_Time = Audio_Play_Interval_Time * 1000
  51. if Audio_Play_Interval_Time < 1000 then
  52.   Audio_Play_Interval_Time = 1000
  53. end
  54.
  55. -- Create HTML content
  56. page = [[
  57. <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
  58. <html xmlns="http://www.w3.org/1999/xhtml">
  59. <head>
  60. <meta http-equiv="Content-Type" content="text/html; charset=utf-8" />
  61. <title>homeLYnk Alarm Notifications</title>
  62. <style type="text/css">
  63. body {
  64. background-color: transparent;
  65. }
  66. </style>
  67. </head>
  68. <body>
  69. <script type="text/javascript">
  70. // ***** Make link to parent from iframe *****
  71. var p = window.parent, root, addr;
  72. var ip = location.host;
  73. var URL = "http://" + ip + "/scada/resources/img/";
  74.
  75. if (p && p.objectStore) {
  76. ]]
  77. if Audio_on_value_1_only == false then
  78. page = page .. [[
  79. // Create snd for playing audio
  80. var snd_0 = new Audio(URL + "alarm_0.]] .. Audio_File_Format_0 .. [[");
  81. var snd_1 = new Audio(URL + "alarm_1.]] .. Audio_File_Format_1 .. [[");
  82. ]]
  83. else
  84. page = page .. [[
  85. // Create snd for playing audio
  86. var snd_1 = new Audio(URL + "alarm_1.]] .. Audio_File_Format_1 .. [[");
  87. // Create alertaudio for loop playing audio
  88. var alertaudio = ""
  89.
  90. function playalert_loop() {
  91. if (snd_1.paused || snd_1.ended || snd_1.currentTime == 0 ) {
  92.     snd_1.play();
  93. }
  94. }
  95.
  96. function playalert() {
  97. // Create loop
  98. if(alertaudio==""){
  99.     alertaudio = window.setInterval("playalert_loop()",]] .. Audio_Play_Interval_Time .. [[);
  100.   }
  101. // Start loop direct
  102. playalert_loop();
  103. }
  104.
  105. function stopalert() {
  106. if(alertaudio!=""){
  107. window.clearInterval(alertaudio)
  108.     alertaudio=""
  109. }
  110. if (!snd_1.paused || !snd_1.ended || snd_1.currentTime > 0 ) {
  111.     snd_1.pause();
  112. snd_1.currentTime = 0;
  113. }
  114. }
  115. ]]
  116. end
  117. page = page ..  [[
  118. /* ********** DON'T CHANGE ANYTHING ABOVE THIS LINE ******* */
  119. /* ********** HTML FILE FOR HOMELYNK AUDIO MESSAGES  ******* */
  120. /* ************** CREATED BY ERWIN VAN DER ZWART ********** */
  121. /* ******************************************************** */
  122. /*  TO ADD COPY BLOCK(S) AND CHANGE (2x) addr0 to addr(x)  */
  123. /* ******************************************************** */
  124.
  125.   /* START BLOCK */
  126. /* ]] .. Audio_Trigger_Group_Address .. [[ = ALARM TRIGGER ADDRES */
  127. addr0 = p.Scada.encodeGroupAddress(']] .. Audio_Trigger_Group_Address .. [[');
  128. p.objectStore.addListener(addr0, function(obj, type) {
  129.
  130. /* to avoid play on opening page */
  131.     if (type == 'init') {]]
  132. if Start_On_Load == false then
  133. page = page .. [[
  134.     return;
  135.   ]]
  136. end
  137. page = page .. [[
  138.     }
  139. ]]
  140. if Audio_on_value_1_only == false then
  141. page = page .. [[
  142.
  143.   if ( obj.value == 0 ) {
  144.   if (!snd_0.paused || !snd_0.ended || snd_0.currentTime > 0 ) {
  145.     snd_0.pause();
  146. snd_0.currentTime = 0;
  147. }
  148.     if (!snd_1.paused || !snd_1.ended || snd_1.currentTime > 0 ) {
  149.     snd_1.pause();
  150. snd_1.currentTime = 0;
  151. }
  152. snd_0.play();
  153.   }
  154.
  155.   if ( obj.value == 1 ) {
  156. if (!snd_0.paused || !snd_0.ended || snd_0.currentTime > 0 ) {
  157.     snd_0.pause();
  158. snd_0.currentTime = 0;
  159. }
  160.     if (!snd_1.paused || !snd_1.ended || snd_1.currentTime > 0 ) {
  161.     snd_1.pause();
  162. snd_1.currentTime = 0;
  163. }
  164.   snd_1.play();
  165. }
  166. ]]
  167. else
  168.   if Stop_on_value_0 == true then
  169.     if Repeat_on_value_1 == true then
  170.     page = page .. [[
  171.
  172.   if ( obj.value == 0 ) {
  173.     stopalert();
  174.   }
  175.
  176.   if ( obj.value == 1 ) {
  177.   playalert();
  178. }
  179. ]]
  180.   else
  181. page = page .. [[
  182.
  183.     if ( obj.value == 0 ) {
  184.     if (!snd_1.paused || !snd_1.ended || snd_1.currentTime > 0 ) {
  185.     snd_1.pause();
  186. snd_1.currentTime = 0;
  187. }
  188.   }
  189.
  190.   if ( obj.value == 1 ) {
  191.   if (!snd_1.paused || !snd_1.ended || snd_1.currentTime > 0 ) {
  192.     snd_1.pause();
  193. snd_1.currentTime = 0;
  194. }
  195. snd_1.play();
  196. }
  197. ]]
  198.   end
  199.   else
  200.     page = page .. [[
  201.
  202.     if ( obj.value == 0 ) {
  203.
  204.   }
  205.
  206.   if ( obj.value == 1 ) {
  207.   if (!snd_1.paused || !snd_1.ended || snd_1.currentTime > 0 ) {
  208.     snd_1.pause();
  209. snd_1.currentTime = 0;
  210. }
  211. snd_1.play();
  212. }
  213. ]]
  214.   end
  215. end
  216. page = page ..  [[
  217.   });
  218. /* END OF ]] .. Audio_Trigger_Group_Address .. [[ */
  219.
  220. /* ******************************************************** */
  221.
  222. /* ******************************************************** */
  223. /*  TO ADD COPY BLOCK(S) AND CHANGE (2x) addr0 to addr(x)  */
  224. /* ******************************************************** */
  225.
  226. // ADD HERE EXTRA BLOCKS IF NEEDED
  227.
  228. /* ******************************************************** */
  229.
  230. /* ********** DON'T CHANGE ANYTHING BELOW THIS LINE ******* */
  231.
  232. }
  233. </script>
  234. </div>
  235. </body>
  236. </html>
  237. ]]
  238.
  239. -- Write HTML file to controller
  240. io.writefile("/www/scada/resources/img/alarm.html", page)
  241.
  242. -- use this as frame URL -> /scada/resources/img/alarm.html
  243.
  244. -- Check if html must be automaticly created inside iframe with alarm.html on startpage
  245. if Create_Automatic == true then
  246.
  247.   -- Get default startpage
  248.   query = 'SELECT id, usermode_param FROM visfloors'
  249. for _, floor in ipairs(db:getall(query)) do
  250. if floor.usermode_param == "D" then
  251.     default_startpage = floor.id
  252. end
  253. end
  254.
  255.   -- Check if default page excists else exit script
  256.   if default_startpage == nil then
  257.     alert("Default page does not excists, exit HTML creation")
  258.     --Exit script
  259.     return
  260.   end
  261.
  262.   -- Check if object already exist
  263.   object_exists = false
  264.   query = 'SELECT floor, type, name, params FROM visobjects'
  265.   for _, visobject in ipairs(db:getall(query)) do
  266.     if visobject.floor == default_startpage and (visobject.type == 9 or visobject.type == "9") and visobject.name == "alarm" then
  267.       object_exists = true
  268.     end
  269. end
  270.
  271.   -- Create if object doesn't exist
  272.   if object_exists == false then
  273.   db:insert('visobjects', {floor = default_startpage, type = 9, params = '{"source":"url","url":"/scada/resources/img/alarm.html","width":50,"height":50}', locx = 0 , locy = 0, name = "alarm", notouch = 1, nobg = 1,})
  274.   end
  275.
  276.   if Audio_on_value_1_only == false then
  277.   -- Download alarm file on value 0 to controler local
  278.     os.execute('wget -q -U Mozilla -O /www/scada/resources/img/alarm_0.' .. Audio_File_Format_0 .. ' ' ..  URL_Audio_File_0)
  279.     -- Download alarm file on value 1 to controler local
  280.   os.execute('wget -q -U Mozilla -O /www/scada/resources/img/alarm_1.' .. Audio_File_Format_1 .. ' ' ..  URL_Audio_File_1)
  281.   else
  282.     -- Download alarm file on value 1 to controler local
  283.   os.execute('wget -q -U Mozilla -O /www/scada/resources/img/alarm_1.' .. Audio_File_Format_1 .. ' ' ..  URL_Audio_File_1)
  284.   end
  285. end
  286.
  287. log ("Audio alerts are added")
  288.
  289. -- Check if HTML logout function must be deleted from the controller
  290. if Delete_HTML == true then
  291.
  292.   -- Get default startpage
  293.   query = 'SELECT id, usermode_param FROM visfloors'
  294. for _, floor in ipairs(db:getall(query)) do
  295. if floor.usermode_param == "D" then
  296.     default_startpage = floor.id
  297. end
  298. end
  299.
  300.   -- Check if default page excists else exit script
  301.   if default_startpage == nil then
  302.     alert("Default page does not excists, exit HTML deletion")
  303.     --Exit script
  304.     return
  305.   end
  306.
  307.   -- Select all entrys from DB inside table 'visobjects'
  308.   query = 'SELECT id, floor, type, name, params FROM visobjects'
  309. for _, visobject in ipairs(db:getall(query)) do
  310.   if visobject.floor == default_startpage and (visobject.type == 9 or visobject.type == "9") and visobject.name == "alarm" then
  311.       current = visobject.id
  312.       db:delete('visobjects', { id = current })
  313.     end
  314.   end
  315.
  316.   --Delete HTML file from HL dir
  317.   os.remove("/www/scada/resources/img/alarm.html")
  318.
  319.   if Audio_on_value_1_only == false then
  320.   --Delete Audio file on value 0 from HL dir
  321.   os.remove("/www/scada/resources/img/alarm_0." .. Audio_File_Format_0)
  322.
  323.     --Delete Audio file on value 1from HL dir
  324.   os.remove("/www/scada/resources/img/alarm_1." .. Audio_File_Format_1)
  325.   else
  326.     --Delete Audio file on value 1from HL dir
  327.   os.remove("/www/scada/resources/img/alarm_1." .. Audio_File_Format_1)
  328.   end
  329.   log ("Audio alerts are deleted")
  330. end
  331.
  332. -- Disable script when done automaticly
  333. script.disable(_SCRIPTNAME)
sound - by balatis - 25.03.2020, 12:37
RE: sound - by admin - 25.03.2020, 13:15
RE: sound - by balatis - 26.03.2020, 20:56
RE: sound - by Erwin van der Zwart - 23.08.2020, 09:41
RE: sound - by Domoticatorino - 21.08.2020, 14:25
RE: sound - by Domoticatorino - 23.08.2020, 15:46
