Popup Position
(26.03.2020, 11:09)Daniel. Wrote: Why don't you just put it on a widget and each widget has custom position option out of the box?
Sorry but I do not understand. I explain well how I did it.
I have a button that opens a page of "Air conditioning", I select a "plant" and then a "stay". Plant and room are already widgets with a specific position.
The thermostat that I enclose in the image has a setpoint temperature object, it is the lower one to the right of 20º and when pressing the slider I wanted to center it with the image of the widget. And if I have several slider in a widget, if you can assign specific position of each one.
Popup Position - by tom77 - 29.11.2015, 20:11
RE: Popup Position - by admin - 01.12.2015, 08:23
RE: Popup Position - by baggins - 16.02.2017, 13:23
RE: Popup Position - by admin - 16.02.2017, 13:42
RE: Popup Position - by baggins - 16.02.2017, 15:42
RE: Popup Position - by admin - 16.02.2017, 16:08
RE: Popup Position - by davidchispas - 25.03.2020, 17:02
RE: Popup Position - by admin - 26.03.2020, 09:03
RE: Popup Position - by davidchispas - 26.03.2020, 10:31
RE: Popup Position - by Daniel - 26.03.2020, 11:09
RE: Popup Position - by davidchispas - 26.03.2020, 11:36
RE: Popup Position - by Daniel - 26.03.2020, 12:07
RE: Popup Position - by davidchispas - 26.03.2020, 12:38
RE: Popup Position - by davidchispas - 26.03.2020, 14:43
RE: Popup Position - by Daniel - 26.03.2020, 15:12
RE: Popup Position - by davidchispas - 26.03.2020, 15:46
RE: Popup Position - by admin - 26.03.2020, 15:52
RE: Popup Position - by Joep - 02.04.2020, 14:47
