01.04.2020, 10:19
(01.04.2020, 08:20)admin Wrote: The problem is that 50/0/0 arrives after 50/0/4 when your script is already executing.
Attach your script to 50/0/0 and modify it like this:
Code:Scanner_Value = event.getvalue() --07.2bytes, user id Scanner_Rele = grp.getvalue('50/0/4') --01.1bit, only send true
Hello Admin, I already did that test. I also have the same problem, the value of 1 bit is always true. Therefore, the condition will also be fulfilled.
Is it possible not to run the script until the two values are updated? That one value depends on the other to be executed.
