Creat logs in txt file
I "stole" this script (thank you). It runs perfect, but how can I access (download to PC) the CSV file produced?
I have tried Filezilla and can access the Wiser/SL successfully, but neither the user "ftp" nor the user "app" display anything that resembles "/tmp/......" which is the path used above in the following line: result, err = io.writefile ('/tmp/'..logfile, table.concat(buffer, '\r\n'))
Thanks in advance
Creat logs in txt file - by deimostier - 27.04.2017, 14:03
RE: Creat logs in txt file - by gtsamis - 27.04.2017, 21:55
RE: Creat logs in txt file - by deimostier - 02.05.2017, 14:41
RE: Creat logs in txt file - by gtsamis - 02.05.2017, 14:51
RE: Creat logs in txt file - by mjaanes - 02.04.2020, 10:11
RE: Creat logs in txt file - by admin - 02.04.2020, 11:20
RE: Creat logs in txt file - by tassiebean - 12.06.2020, 15:10
RE: Creat logs in txt file - by Trond Hoyem - 13.08.2020, 09:46
RE: Creat logs in txt file - by Trond Hoyem - 07.01.2021, 12:02
RE: Creat logs in txt file - by admin - 12.06.2020, 15:47
RE: Creat logs in txt file - by tassiebean - 13.06.2020, 03:20
RE: Creat logs in txt file - by admin - 13.08.2020, 11:12
RE: Creat logs in txt file - by admin - 07.01.2021, 12:14
RE: Creat logs in txt file - by phongvucba - 18.06.2024, 08:03
RE: Creat logs in txt file - by admin - 18.06.2024, 08:14
RE: Creat logs in txt file - by phongvucba - 18.06.2024, 08:27
RE: Creat logs in txt file - by Daniel - 18.06.2024, 08:33
RE: Creat logs in txt file - by phongvucba - 18.06.2024, 08:35
RE: Creat logs in txt file - by admin - 18.06.2024, 08:36
RE: Creat logs in txt file - by phongvucba - 18.06.2024, 08:44
RE: Creat logs in txt file - by Daniel - 18.06.2024, 08:48
RE: Creat logs in txt file - by phongvucba - 18.06.2024, 08:57
RE: Creat logs in txt file - by Daniel - 18.06.2024, 09:02
RE: Creat logs in txt file - by phongvucba - 18.06.2024, 09:12
RE: Creat logs in txt file - by Daniel - 18.06.2024, 09:12
RE: Creat logs in txt file - by admin - 18.06.2024, 09:15
RE: Creat logs in txt file - by phongvucba - 18.06.2024, 10:00
