Logging & Monitoring KNX activity
just a feedback on haw I have implemented the monitoring of the knx network of my house
As it is also inspired from several thread of this forum, it make sense to make it
As I am not a LUA / LogicMachine expert, some part of the code can be improved for such, but it works...
First I have used "tags" feature of KNX object in order to define the type of logging I want on each object
- "tobelogged" for immediate logging (for use of light by example)
- "tobelogged-tempo5" for logging but with 5mn min between each measure point (for power usage by example, time delay can be adapted, duplicated, etc)
Both type of logging are based on "Event-based" scripts, they :
- do not log again the same value, I use the LM storage to store trace of last logging activity per object in order to optimize it
- store temporary "event information to be stored in a database" in the LM storage too (would be possible to used MQTT instead in the futur ?)
-> it is possible to add new / other type of "event logging fonction"
A third script scan items in the LM storage every 30s, send them to a database and finally delete them in the LM storage
--********************************* -- --  Event-based / "Event logger immediat" triggered by tag = "tobelogged" of KNX objects -- --********************************* require('json') local obj = grp.find(event.dst) -- log("EVENT LOGGER IMMEDIAT") -- (measureOn, name, source, type, value) var11 = os.date("%Y-%m-%d %H:%M:%S",obj.updatetime) var12 = string.trim(tostring(obj.name)) var13 = string.trim(tostring(obj.address)) var14 = string.trim(tostring(obj.data)) var15 = string.trim(tostring(obj.tagcache)) trace1 = storage.get('TABLE_' .. var13, '') if trace1 == '' then     --log("CREATING TRACE FOR " .. var13)   saveDataToLocalStorage('TABLE_', var11, var12, var13, var14, var15, obj.updatetime)   else     --log("UPDATING TRACE FOR : " .. var13)     if string.trim(tostring(trace1[2])) == string.trim(tostring(var14)) then         --log("NO LOG / NO VALUES CHANGE for : " .. var14)       else         --log("TRACE UPDATED FOR : " .. var13)     saveDataToLocalStorage('TABLE_', var11, var12, var13, var14, var15, obj.updatetime)     end end
--********************************* -- --  Event-based / "Event logger tempo 5" triggered by tag = "tobelogged-tempo5" of KNX objects -- --********************************* require('json') local obj = grp.find(event.dst) --log("EVENT LOGGER TEMPO 5") -- (measureOn, name, source, type, value) local var21 = tostring(os.date("%Y-%m-%d %H:%M:%S",obj.updatetime)) local var22 = string.trim(tostring(obj.name)) local var23 = string.trim(tostring(obj.address)) local var24 = string.trim(tostring(obj.data)) local var25 = string.trim(tostring(obj.tagcache)) local trace2 = storage.get('TABLE_TEMPO_5_' .. var23, '') if trace2 == '' then     saveDataToLocalStorage('TABLE_TEMPO_5_', var21, var22, var23, var24, var25, obj.updatetime)   else     if string.trim(tostring(trace2[2])) == string.trim(tostring(var24)) then         --log("NO LOG / NO VALUES CHANGE for : " .. var24)       else         local diff = math.abs(os.time() - tonumber(trace2[3]))         if diff > 300 then             saveDataToLocalStorage('TABLE_TEMPO_5_', var21, var22, var23, var24, var25, obj.updatetime)           else             --log("NO LOG / TOO EARLY FOR: " .. var23 .. " -> " .. tostring(diff) )           end       end   end
--********************************* -- --  user function / "saveDataToLocalStorage" --  store event (knx or other source) to the LM storage -- --********************************* function saveDataToLocalStorage(traceName, var1, var2, var3, var4, var5, var6)        require('json')     local key = "LOG-" .. tostring(var1) .. "-" .. tostring(var3)   local data = {}   data["timestamp"] = tostring(var1)   data["name"] = tostring(var2)   data["source"] = tostring(var3)   data["value"] = tostring(var4)   data["tagcache"] = string.split(tostring(var5), ",")   storage.set(key, json.encode(data))   local newtrace = {}   newtrace[1] = var1   newtrace[2] = var4   newtrace[3] = var6   storage.set(traceName .. tostring(var3), newtrace)   --log("TRACE UPDATED FOR : " .. var3) end
--********************************* -- --  resident script / triggered every 30s, scan LM storage, send LOG items to database if any and then delete them in the LM storge after -- --********************************* require('luasql.mysql') require('json') http = require('socket.http') key_table = storage.all() for key, value in next, key_table do   --log("looking at : " .. key)   tmp = string.find(key,"LOG-")   if tmp == nil then     --log("data DO NOT match : " .. key .. " - tmp : " .. tostring(tmp) )   else     if tmp >= 0 then       --log("data match : " .. key .. " - tmp : " .. tostring(tmp) )       local data_tab = json.decode(value)          local t = data_tab.tagcache             local series = ""       local series_name = ""       local tagss = ""       local i = 1       for k in next, t do         if i == 2 then           series = string.trim(tostring(t[k]))         end         if i == 3 then           series_name = string.trim(tostring(t[k]))         end         if i > 3 then           tagss = tagss .. string.trim(tostring(t[k])) .. ";"         end         i = i + 1       end       if not tagss == "" then           tagss = string.sub(tagss, 1 , string.len(tagss)-1 )       end       local t1 = string.trim(tostring(data_tab.timestamp))       local Y =  tonumber(string.sub(t1, 1, 4))       local M =  tonumber(string.sub(t1, 6, 7))       local D =  tonumber(string.sub(t1, 9, 10))       local h =  tonumber(string.sub(t1, 12, 13))       local m =  tonumber(string.sub(t1, 15, 16))       local s =  tonumber(string.sub(t1, 18, 19))          local t2 = os.time({year=Y, month=M, day=D, hour=h, min=m, sec=s, isdst = false})       -- txt is the data part of the http command to be send to an influxDb instance in order to store it       -- to prepare the migration i would like to do by the end of the year       local txt = string.trim(tostring(series)) .. ",tags=" .. string.trim(tostring(tagss)) .. ",source=" .. string.trim(tostring(data_tab.source)) .. " " .. series_name .. "=" .. string.trim(tostring(data_tab.value)) .. " " .. string.trim(tostring(t2) )             -- Store data into MariaDB / MySQL             errcur = nil       local DB_NAME = 'MyDBname'       local USERNAME = 'MyUSer'       local PASSWORD = 'MyPwd'       local MYSQL_SERVER_IP = '192.168.0.xxx'       local MYSQL_SERVER_PORT = '3307'       env = luasql.mysql()       dbcon, errcon = env:connect(DB_NAME, USERNAME, PASSWORD, MYSQL_SERVER_IP, MYSQL_SERVER_PORT)       cmd = 'INSERT INTO measures (measureOn, name, source, value, raw) VALUES (\"' .. string.trim(tostring(data_tab.timestamp)) .. '\", \"' .. string.trim(tostring(data_tab.name)) .. '\", \"' .. string.trim(tostring(data_tab.source)) .. '\", \"' .. string.trim(tostring(data_tab.value)) .. '\", \"' .. string.trim(tostring(txt)) .. '\")'       --log("SENDING CMD : " .. cmd)       cursor, errcurs = dbcon:execute ( cmd )       -- manage errors       if (tostring(errcurs) == "nil") then         --log("CMD done !")         storage.delete(key)         --log("KEY REMOVED : " .. key)       else         log("CMD error : " .. tostring(errcurs))       end           end   end end
the block of code dealing with mysql can be replaced by the following one in order to send it to an InfluxDB instance instead
      -- Store data into influxDB       local INFLUX_SERVER_IP = '192.168.0.xx'       local INFLUX_SERVER_PORT = '8086'       local INFLUX_DB_NAME = 'MyDBname'       http.TIMEOUT = 5       res, errh = http.request("http://" .. INFLUX_SERVER_IP ..":" .. INFLUX_SERVER_PORT .. "/write?db=" .. INFLUX_DB_NAME .. "&precision=s", txt)             -- manage errors       if (tostring(errcurs) == "nil") then --and not errh == 204 ) then         --log("CMD done !")         storage.delete(key)         --log("KEY REMOVED : " .. key)       else         log("CMD error : " .. tostring(errcurs))         log("InfluxDB INSERT ERROR", res, errh)       end
MQTT server would be a good candidat to replace LM local storage, maybe a next improvement
the use of LM storage can be a problem : if you store too many item in it (in case of issue on you database or your network by example), your LM might be really really slow
-> this solution is not for production as is but only for personal / home use
hope it will be helpful for some of you
Best regards
Logging & Monitoring KNX activity - by olivier - 10.04.2020, 17:09
