HelvarNet
Try this script to check communication to HelvarNet. It will send query command every 3 seconds. If this works then status map to group address can be implemented.
Resident script, sleep time = 0. Change 192.168.1.1 to HelvarNet router IP. Change 1.1.2.15 to the address of the device you want to query. You will get raw and parsed replies in Logs tab.
if not sock then   ip = '192.168.1.1'   sock = require('socket').udp()   sock:setsockname('*', 60001)   sock:settimeout(1)   ptime = os.time()   function parseitem(res, item)     if item:sub(1, 1) == '@' then       if item:find('=') then         local addr, val = unpack(item:split('='))         res.addr = addr:sub(2)         res.val = val       end     elseif item:find(':') then       local key, val = unpack(item:split(':'))       res[ key ] = val     end   end   function parse(data)     local res = {}     if not data:find('#') then       return     end     res.type = data:sub(1, 1)     data = data:sub(2, -2)     local items = data:split(',')     for _, item in ipairs(items) do       parseitem(res, item)     end     log(res)   end end data = sock:receive() if data then   log(data)   parse(data) end ctime = os.time() if (ctime - ptime) >= 3 then   ptime = ctime   sock:sendto('>V:1,C:152,@1.1.2.15#', ip, 50001) end
HelvarNet - by victor.back - 17.04.2020, 07:56
RE: HelvarNet - by admin - 21.04.2020, 14:59
RE: HelvarNet - by victor.back - 07.05.2020, 08:42
RE: HelvarNet - by admin - 07.05.2020, 10:30
RE: HelvarNet - by victor.back - 07.05.2020, 13:21
RE: HelvarNet - by djaval - 16.02.2024, 11:40
