Ping IP doesn't work
It does not work because you've set the result to variable with the same name as the function. So ping is no longer a function but boolean variable.
Another thing is that if/else is not needed, you can pass the result directly to checkwrite:
function ping(ip)   local res = os.execute('ping -c 2 -W 5 ' .. ip)   return res == 0 end res = ping('192.168.45.1') grp.checkwrite('11/0/1', res)
Ping IP doesn't work - by MantasJ - 08.08.2019, 07:30
RE: Ping IP doesn't work - by Daniel - 08.08.2019, 07:49
RE: Ping IP doesn't work - by admin - 08.08.2019, 07:49
RE: Ping IP doesn't work - by MantasJ - 08.08.2019, 08:10
RE: Ping IP doesn't work - by Daniel - 08.08.2019, 08:19
RE: Ping IP doesn't work - by MantasJ - 08.08.2019, 08:34
RE: Ping IP doesn't work - by AlexLV - 22.04.2020, 21:23
RE: Ping IP doesn't work - by admin - 23.04.2020, 05:07
RE: Ping IP doesn't work - by AlexLV - 23.04.2020, 08:16
RE: Ping IP doesn't work - by djaval - 24.04.2024, 08:05
RE: Ping IP doesn't work - by admin - 24.04.2024, 08:47
RE: Ping IP doesn't work - by khalil - 30.01.2025, 09:44
RE: Ping IP doesn't work - by admin - 30.01.2025, 11:35
RE: Ping IP doesn't work - by khalil - 30.01.2025, 11:40
RE: Ping IP doesn't work - by admin - 30.01.2025, 11:41
