Blocking delay
Do not use sleep function from the example above. This function consumes all CPU resources but will not block anything. For normal delays use built-in sleep function.
If you need to prevent scripts from running the same code simultaneously then use semaphores.
This example will wait for up to 5 seconds for semaphore named eventlock to be become unlocked. If semaphore is unlocked then dosomething is executed. pcall is needed to catch any execution errors. Otherwise semaphore might remain locked if dosomething fails with an error.
If semaphore is still locked after 5 seconds then no function is executed.
require('sem') function dosomething()   -- do something here end stat, err = sem.runlocked('eventlock', 5, function(lockres)   if lockres then     return pcall(dosomething)   else     return nil, 'lock failed'   end end) if stat then   log('ok') else   log('error', err) end
This depends on what kind of locking you need. If you just need to some tasks in sequence (queue) then a resident script might be a better solution.
Blocking delay - by benanderson_475 - 24.04.2020, 22:09
RE: Blocking delay - by AlexLV - 25.04.2020, 04:39
RE: Blocking delay - by benanderson_475 - 29.04.2020, 21:35
RE: Blocking delay - by admin - 25.04.2020, 07:38
RE: Blocking delay - by admin - 30.04.2020, 04:38
RE: Blocking delay - by AlexLV - 30.04.2020, 16:00
