Logger All Datagrams KNX BUS to mysql
This is my code, maybe not perfect but it works
--[[ * table: [datalen]   * number: 4 [datahex]   * string: 453FE000 [data]   * number: 3070 [srcraw]   * number: 8448 [dstraw]   * number: 17930 [type]   * string: groupwrite [src]   * string: 2.1.0 [dst]   * string: 8/6/10 --]] if not client then   require('genohm-scada.eibdgm')   objects = grp.all()   datatypes = {}   for _, object in ipairs(objects) do     datatypes[ object.id ] = {object.name, object.datatype}   end     function writemysql(I_datalen,I_datahex,I_data,I_srcraw,I_dstraw,I_type,I_src,I_dst,I_name)       require('luasql.mysql')     env = luasql.mysql()     dbcon = env:connect('xxxxxxxxx', 'xxxxxxx', 'xxxxxxxx', '192.168.12.25', '3306')     if dbcon then       if I_type == 'groupread' then         cursor = dbcon:execute( 'insert into datalog (datetime,datalen,srcraw,dstraw,type,src,dst,dstname) values (now(),'..I_datalen..','..I_srcraw..','..I_dstraw..',"'..I_type..'","'..I_src..'","'..I_dst..'","'..I_name..'") ' )       else           cursor = dbcon:execute( 'insert into datalog (datetime,datalen,datahex,data,srcraw,dstraw,type,src,dst,dstname) values (now(),'..I_datalen..',"'..I_datahex..'",'..tostring(I_data)..','..I_srcraw..','..I_dstraw..',"'..I_type..'","'..I_src..'","'..I_dst..'","'..I_name..'") ' )        end       --log(cursor)       dbcon:close()       env:close()     end   end     function writehandler(event)     if datatypes[ event.dstraw ] then       name = datatypes[ event.dstraw ][1]         dpt = datatypes[ event.dstraw ][2]     else       name = ''     end     if dpt then       event.data = knxdatatype.decode(event.datahex, dpt)     else         event.data = nil      end     --log(event)     writemysql(event.datalen,event.datahex,event.data,event.srcraw,event.dstraw,event.type,event.src,event.dst,name)   end   function readhandler(event)     if datatypes[ event.dstraw ] then         name = datatypes[ event.dstraw ][1]     else       name = ''     end     --log(event)     writemysql(event.datalen,event.datahex,'',event.srcraw,event.dstraw,event.type,event.src,event.dst,name)   end   -- knx connection   client = eibdgm:new({ timeout = 1 })   client:sethandler('groupwrite', writehandler)   client:sethandler('groupresponse', writehandler)   client:sethandler('groupread', readhandler) end -- handle knx client:step()
RE: Logger All Datagrams KNX BUS to mysql - by gjniewenhuijse - 01.05.2020, 06:35
