Time loop control
I would do it by two scripts. First event attached to your 1/1/1 which will enable/disable the second resident script.
value = event.getvalue() if value then script.enable('loop') else script.disable('loop') end
Second is resident script with interval of 1s and such code.
grp.write('1/1/2', true) os.sleep(1) grp.write('1/1/3', true) os.sleep(1) grp.write('1/1/4', true)
In this example I called resident script 'loop' if you use different name change it in the first script
Time loop control - by 38348259 - 05.05.2020, 13:12
RE: Time loop control - by Daniel - 05.05.2020, 13:25
RE: Time loop control - by 38348259 - 05.05.2020, 13:59
RE: Time loop control - by Daniel - 05.05.2020, 14:03
RE: Time loop control - by 38348259 - 05.05.2020, 14:12
