snmpv3 authPriv issue
Hello to all,
I have been working in the last period to integrate a series of UPS of APC using the snmp protocol.
The version required is v3.
I have used this site: http://luasnmp.luaforge.net/objects.html to get information for the parameters of snmp.
ups1, err = snmp.open{     version = snmp.SNMPv3,   community = "public",   port = 161,   peer = "IP address",   user = "Sotirios",   authPassphrase = "Papantoniou1",   privPassphrase  = "Papantoniou2",   authType = "MD5",   privType = "AES",   timeout = 2,   securityLevel = "authNoPriv",--"noAuthNoPriv",   } assert(ups1, err) log(ups1) log(err) local OID_NAS3 = {     {'Varname',"1.3.6.1.4.1.935.1.1.1.1.1.1.0"},--NEW }   for _, item in ipairs(OID_NAS3) do     vbind, err = ups1:get(item[2])     if vbind then     log(vbind.value)     else       log('error reading from snmp: ' .. tostring(err))       --grp.checkwrite('EL_UPS_communication_KO',true)           end   end
On security level when I am using noAuthNoPriv or authNoPriv everything is working correctly. When I use authPriv adding all the parameters correctly (cross-checked with other 3rd party software) I have problem with the communication.
The log message I got was:
error reading from snmp: snmp: internal error - synch request id is 0
This error arrives even when the parameters I have inserted are wrong. Google searching:"synch request id is 0"  I have found the error on the source code but no explanation why this is happening.https://github.com/hleuwer/luasnmp/blob/.../nm_snmp.c
Has anybody else found a similar problem? How can I solve this issue?
Thank you
Sotiris
snmpv3 authPriv issue - by spapantoniou85 - 06.05.2020, 14:46
RE: snmpv3 authPriv issue - by admin - 07.05.2020, 07:46
RE: snmpv3 authPriv issue - by spapantoniou85 - 07.05.2020, 08:20
RE: snmpv3 authPriv issue - by cekca - 31.10.2024, 08:48
RE: snmpv3 authPriv issue - by admin - 31.10.2024, 09:03
RE: snmpv3 authPriv issue - by cekca - 31.10.2024, 09:22
RE: snmpv3 authPriv issue - by cekca - 31.10.2024, 10:32
RE: snmpv3 authPriv issue - by admin - 31.10.2024, 10:53
RE: snmpv3 authPriv issue - by cekca - 31.10.2024, 11:31
RE: snmpv3 authPriv issue - by cekca - 31.10.2024, 13:21
RE: snmpv3 authPriv issue - by admin - 31.10.2024, 13:24
