Linking Multiple LM's
For connection with encryption use this example. Enable MQTT broker with encryption and add a user and password in the Broker app
You may need to reboot LM with broker after changing settings.
if not broker then   broker = '192.168.0.10'     username = 'user'   password = 'password'     socket = require('socket')   port = 8883   function multiply(mult)     return function(value)       local num = tonumber(value)       if num then         return num * mult       else         return value       end     end   end   -- topic to object map   mqtt_to_object = {     ['in/topic1'] = '1/0/0',     ['in/topic2'] = '1/0/19',   }   -- optional topic value conversion function   mqtt_to_object_conv = {   --  ['in/topic1'] = multiply(100),   --  ['in/topic2'] = multiply(0.01),   }   -- object to topic map   object_to_mqtt = {     ['1/0/0'] = 'out/topic1',     ['1/0/19'] = 'out/topic2',   }   datatypes = {}   grp.sender = 'mq'   require('socket')   for addr, _ in pairs(object_to_mqtt) do     local obj = grp.find(addr)     if obj then       datatypes[ addr ] = obj.datatype     end   end   mclient = require('mosquitto').new()   mclient.ON_CONNECT = function(res, ...)     log('mqtt connect status', res, ...)     if res then       for topic, _ in pairs(mqtt_to_object) do         mclient:subscribe(topic)       end     else       mclient:disconnect()     end   end   mclient.ON_MESSAGE = function(mid, topic, payload)     local addr = mqtt_to_object[ topic ]     if addr then       local fn = mqtt_to_object_conv[ topic ]       if fn then         payload = fn(payload)       end       grp.write(addr, payload)     end   end   mclient.ON_DISCONNECT = function(...)     log('mqtt disconnect', ...)     mclientfd = nil   end   function mconnect()     local status, rc, msg, fd     status, rc, msg = mclient:connect(broker, port)     if not status then       log('mqtt connect failed ' .. tostring(msg))     end     fd = mclient:socket()     if fd then       mclientfd = fd     end   end       mclient:tls_insecure_set(true)   mclient:login_set(username, password or '')     mconnect()   function publishvalue(event)     -- message from us or client is not connected     if event.sender == 'mq' or not mclientfd then       return     end     local addr = event.dst     local dpt = datatypes[ addr ]     local topic = object_to_mqtt[ addr ]     -- unknown object     if not dpt or not topic then       return     end     local value = busdatatype.decode(event.datahex, dpt)     if value ~= nil then       if type(value) == 'boolean' then         value = value and 1 or 0       end       mclient:publish(topic, tostring(value))     end   end   lbclient = require('localbus').new(1)   lbclient:sethandler('groupwrite', publishvalue)   lbclientfd = socket.fdmaskset(lbclient:getfd(), 'r')   -- run timer every 5 seconds   timer = require('timerfd').new(5)   timerfd = socket.fdmaskset(timer:getfd(), 'r') end -- mqtt connected if mclientfd then   mclientfdset = socket.fdmaskset(mclientfd, mclient:want_write() and 'rw' or 'r')   res, lbclientstat, timerstat, mclientstat =       socket.selectfds(10, lbclientfd, timerfd, mclientfdset) -- mqtt not connected else   res, lbclientstat, timerstat =     socket.selectfds(10, lbclientfd, timerfd) end if mclientstat then   if socket.fdmaskread(mclientstat) then     mclient:loop_read()   end   if socket.fdmaskwrite(mclientstat) then     mclient:loop_write()   end end if lbclientstat then   lbclient:step() end if timerstat then   -- clear armed timer   timer:read()   if mclientfd then     mclient:loop_misc()   else     mconnect()   end end
Linking Multiple LM's - by sjfp - 05.05.2020, 18:30
RE: Linking Multiple LM's - by Daniel - 06.05.2020, 10:49
RE: Linking Multiple LM's - by sjfp - 06.05.2020, 13:43
RE: Linking Multiple LM's - by sjfp - 11.05.2020, 10:15
RE: Linking Multiple LM's - by Daniel - 11.05.2020, 10:23
RE: Linking Multiple LM's - by sjfp - 11.05.2020, 11:01
RE: Linking Multiple LM's - by Daniel - 11.05.2020, 12:41
RE: Linking Multiple LM's - by sjfp - 11.05.2020, 13:44
RE: Linking Multiple LM's - by Daniel - 11.05.2020, 13:50
RE: Linking Multiple LM's - by admin - 11.05.2020, 13:51
RE: Linking Multiple LM's - by sjfp - 11.05.2020, 15:20
RE: Linking Multiple LM's - by sjfp - 13.05.2020, 09:06
RE: Linking Multiple LM's - by Daniel - 13.05.2020, 09:28
RE: Linking Multiple LM's - by Daniel - 13.05.2020, 13:57
RE: Linking Multiple LM's - by Daniel - 16.05.2020, 16:16
RE: Linking Multiple LM's - by admin - 19.05.2020, 09:17
RE: Linking Multiple LM's - by jmir - 13.08.2021, 16:11
